- Thank you received: 1203
Antonov AN 124 Rusian
- crash happy
I can empathise with that ! stunning job.
And for completeness the result of its 3rd flight.:woohoo:
My proposal is not to repair it immediately but to structurally 'tidy up' the bits so they can be stored safely without risking any further damage.
I have made a start on the fuselage.
As all the engine nacelles are seriously damaged there will have to be many hours of printing.
The fuselage repaired up to the wing leading edge.
Two new formers had to be printed and some skin replaced but at least the relationship between the wing and tail has been retained.
I hate to think how much printing and build time will be required to make the complete nose section.
The engine nacelles needed some thought as three of the pylons are broken and they have the motor wires running up inside them. :woohoo:
No1 nacelle has been repaired with a printed thin (0.5 mm) plate 'patch' glued either side of the pylon over the break.
No2 nacelle has by far the worst damage.
In fact as well as the pylon break the actual motor mount is broken in several places.
Still thinking about how to fix that.
No3 nacelle pylon has been repaired in the same way as No1.
In addition the damaged first 17 mm on the nacelle inlet has been cut away and a replacement printed (45 minutes!) and glued on.
No4 nacelle is undamaged.
Apart from everything else I really want to increase the size of the ailerons and to add a working rudder but the CofG cannot go any further aft. I don't do ballast.
- Thank you received: 10844
Not lack of power (which is surprisingly quite adequate) but a structural failure. :woohoo: The right hand outer wing panel pulled out just far enough to release it from its locating pins!
The wing panel join tube is a 'friction' tight fit but the wing also carries the ailerons so it probably gets 'wiggled' a bit which which may have caused it to work out.
Lesson learned. If and when it gets rebuilt those wing panels will have retaining cross pins as well.
In the video I was flying pretty gently so when the power was off it did not alter the flying speed by much, it just went from slow to slightly slower.
I am not sure about friction fit having no place in RC. Surely it is not uncommon for the wings on many planes to be retained by just a joining tube relying just on friction to stop it working out. My ST330 (a Radian clone) certainly does although in that case the aligning pins (actually more like lugs) are quite big and long.
Anyway I have made some progress on restoring the Antonov.
The wing centre section is restored and the nacelles are all repaired and tested.
As hoped the wing and tail plane are still in line!
I have also arranged for the batteries in the wing to be able to slide further forward actually into the forward fuselage to adjust the CofG both because it flew a bit tail heavy and to be able to compensate for the weight associated by adding a working rudder.
Obviously the next big task is rebuilding the nose. Apart from the physical building time each fuselage former takes up to an hour to print and there are a total of 15 them!
- Ralpharr2001
- Thank you received: 1484
Yes that sort of thing is a possibility but still with a clear mental image of the Antonov spiralling in I favour putting a pin vertically through the spar flanges and through end of the joiner tube. As long as that pin is in place the wing panel might snap off but it simply will not come out.
The outer wing panel joining tubes are quite long so I did not expect any unwanted movement but on the principle of belts and braces the rear locating pins have also been revised so they are both stronger and longer so even if the wing moves out a little bit they will not 'let go'.
Slowly started printing the new fuselage formers.
1 hour 4 minutes to do that lot.
- Thank you received: 14473
No, Klippy, drilling a hole in a carbon spar for a locking screw is not a good idea! :woohoo: Instant stress point! But I think you had already realized that!
