- Thank you received: 14473
Not a DH although I understand the designer used to work for them.
Two started, one completed, flew once and was written off on landing.
Eric
Too many P51Ds!
Its electric - Sikorsky Firefly demonstrator.
The lifting lugs on the battery packs give it away
Quorneng wrote: Klipkopwildlife
/quote]
It's just that the engine is righthand rotation (from the front) so I thought 'Gypsy'
Come to think of it every body considers the Gipsy goes round the wrong way but as a Merlin is geared its crankshaft actually turns to the right from the front!
Attachment mysterydelta.jpg not found
"Recovering from the abrupt takeoff, Richmond carried out a preliminary test flight with gear extended throughout but after only five minutes airborne, while encountering inadequate elevator control, the engine overheated. According to some accounts, Richmond was being scalded by steam from the radiator mounted below the cockpit, and in haste to carry out a forced landing, inadvertently stalled the aircraft at approximately 30 ft above the airfield.[8] Other sources state that the coolant leak only occurred after impact.[9] The aircraft impacted heavily, with the undercarriage driven through the wings, and the tail broken off."
The part finished second one was apparently lying around Heston airfield until the mid 50s and was eventually burnt.
In the meantime a question - did the English Electric Canberra have air brakes?
