Fairey Gannet AEW3
10 Dec 2015 16:35 #91 by Garry Pollard
Replied by Garry Pollard on topic Re:Fairey Gannet AEW3
Works fine for me Dave
10 Dec 2015 17:34 #92 by Skydanz
Replied by Skydanz on topic Re:Re:Fairey Gannet AEW3
Garry Pollard wrote: Works fine for me Dave
Thanks Garry. I went back and edited to bracket the url
Sent from my SM-G925P using Tapatalk
The sky is not the limit... the ground is!
  • Ralpharr2001
10 Dec 2015 18:09 #93 by Ralpharr2001
Replied by Ralpharr2001 on topic Fairey Gannet AEW3
Skydanz wrote: OK... Not sure why the video didn't post but I'll put the link here.
Hi Don,
Yes saw this and the guy that did the excellent work, Windy, contacted me through this forum AND most generously shared the details of his design. Just love the friendly helpful people in this hobby. You should look up Windy's other video's. He's built a superb contra rotating drive unit.
10 Dec 2015 22:18 #94 by one tenor
Replied by one tenor on topic Fairey Gannet AEW3
Just magic .Like the real thing I think
10 Dec 2015 22:25 #95 by Skydanz
Replied by Skydanz on topic Re:Fairey Gannet AEW3
Thanks Ralph. I have seen his other videos. He had a thread going on RCGroups, I believe, when he started building the unit. Amazing work. Too bad it's not for our scale!
Hi Don,
  • Ralpharr2001
27 Dec 2015 12:12 #96 by Ralpharr2001
Replied by Ralpharr2001 on topic Re:Fairey Gannet AEW3
Have had some productive time on the Gannet. Made the hinges and RDS wiper boxes for the ailerons and fitted them. So ailerons are now hinged and ready for the RDS system to be installed.
I was going to use 2mm bolts and nuts but decided this was a bit crude so made some 2mm dia brass pins with a split pin to secure them. There will be a crinkle washer between the split pin and hinge.
There will be a cover plate (made from litho plate and small screws) over each hinge point so the big gap you see will be closed off.
Now it all works just need to strip it all down and tidy it up. Next job is to add the secondary spars for the aileron trim tabs, sheet each aileron and cut the trim tabs out.
Thanks: Eric, Quorneng, THE BLACKBIRD, boz, Skydanz
27 Dec 2015 12:27 #97 by Ex-Member
Replied by Ex-Member on topic Fairey Gannet AEW3
lovely work as usual sir.
can't wait to see this one finished. :cheer: :cheer:
27 Dec 2015 15:44 #98 by Skydanz
Ralpharr2001 wrote: Have had some productive time on the Gannet. Made the hinges and RDS wiper boxes for the ailerons and fitted them. So ailerons are now hinged and ready for the RDS system to be installed.
Sweet! So exciting seeing get to this stage. Will you make the trim tabs "functional"?
27 Dec 2015 16:02 - 27 Dec 2015 16:04 #99 by Skydanz
Last edit: 27 Dec 2015 16:04 by Skydanz.
  • Ralpharr2001
27 Dec 2015 16:11 #100 by Ralpharr2001
Hi Don, no the trim tabs will be for show but perhaps on the Mklll version!
27 Dec 2015 16:24 #101 by Skydanz
I understand. Just another level of frustration to build. I have not had any luck opening the file. I can open .dxf though, if only to follow along with your build.
27 Dec 2015 16:56 - 27 Dec 2015 16:56 #102 by Skydanz
Ralph, do you need any pictures of the outer wing fold joint? They are rather rare.
Don
Last edit: 27 Dec 2015 16:56 by Skydanz.
  • Ralpharr2001
27 Dec 2015 17:27 #103 by Ralpharr2001
That would be great Don, as you say pictures of the outer wing fold are rare.
The drawing file I sent you is in solidworks format so will need solidworks or solidworks drawing reader to view it. It does take a while to open.
27 Dec 2015 19:57 #104 by Eric
Replied by Eric on topic Re:Fairey Gannet AEW3
I think I have a couple of folded Gannet pics, but they will probably be too small to be of use, as they were taken with an Instamatic, from the flag-deck/goofing platform, and the Gannets were always parked on t'other side of the deck.
  • Ralpharr2001
27 Dec 2015 20:20 #105 by Ralpharr2001
All pictures welcome Eric. They all add background to the build. :cheer:
Time to create page: 1.550 seconds
