12 Dec 2016 19:20 #1 by THE BLACKBIRD
Own design and build sports turbine jet was created by THE BLACKBIRD
Been doing a little on it, fuselage profile nearly sorted
Sorry the pic's are not to good
Thanks: Klipkopwildlife, Quorneng, Firewood
12 Dec 2016 19:29 #2 by Ex-Member
Replied by Ex-Member on topic Own design and build sports turbine jet
Lovely looking design sir.
get her built sir. :P
15 Dec 2016 20:20 #3 by THE BLACKBIRD
Did a bit of drawing, doing the profiles for the fuselage
Thanks: Klipkopwildlife, Ex-Member, Quorneng, Kintosh
16 Dec 2016 14:15 #4 by Eric
Replied by Eric on topic Own design and build sports turbine jet
BB, you seem to be designing that model with a deep but narrow fuselage. Would it not be better for you with a shallower but wider one - easier to get your hands into?
16 Dec 2016 19:26 #5 by THE BLACKBIRD
Hi Eric the fuselage is 240mm deep and a 180mm wide and 1087 long a n d after the turbine it is 1110mm deed down to 70mm deep and obviously tapers to 30mm wide at the rear end :)
Been doing more fuselage profiles tonight, I going to do it in fibre glass, I think :unsure:
16 Dec 2016 19:34 #6 by old fart
Replied by old fart on topic Own design and build sports turbine jet
What turbine are you going to use? :)
16 Dec 2016 20:30 - 16 Dec 2016 20:42 #7 by THE BLACKBIRD
A Jet Cat 100RX Owen 10 kg thrust or for Garry 22lbs so I hope to get it built for twenty lbs or less
Oops that should read 110mm deep and1870 mm long not 1087 :silly:
Last edit: 16 Dec 2016 20:42 by THE BLACKBIRD.
Thanks: boz, Kintosh
20 Dec 2016 19:55 - 20 Dec 2016 19:55 #8 by THE BLACKBIRD
Bought the first piece for the jet today, a length of 22mm ally pipe
Can you guess what its for ;)
Last edit: 20 Dec 2016 19:55 by THE BLACKBIRD.
Thanks: Klipkopwildlife, boz
21 Dec 2016 20:46 - 21 Dec 2016 20:50 #9 by THE BLACKBIRD
Is anybody looking at this, wont waste my time if there is no interest
Got another bit for it today
Could not get any blue foam but this looks very dense and the factory I got it from said its better
Time will tell, actually made a start on it
Last edit: 21 Dec 2016 20:50 by THE BLACKBIRD.
Thanks: Klipkopwildlife, Ex-Member, Quorneng, one tenor, boz, Kintosh
21 Dec 2016 21:04 #10 by Garry Pollard
Replied by Garry Pollard on topic Own design and build sports turbine jet
Well, 12 "thank you's seem to say that there IS interest in this thread. Thats more than I have ever had :woohoo: :woohoo: :woohoo: :evil: [badass]
Take it off, and i will set Pol on to you B) B) :sick: :sick:
21 Dec 2016 21:12 #11 by Ex-Member
is it a centering tube for the fuselage blocks.
22 Dec 2016 04:00 #12 by one tenor
Looks great foam I wish I could get some like that [badass]
22 Dec 2016 05:52 #13 by THE BLACKBIRD
Ha Ha I think the clue in the last pic made it to easy Tony :P
22 Dec 2016 07:34 - 22 Dec 2016 07:36 #14 by THE BLACKBIRD
My gremlins strike again :( just went to the hanger to do a bit as its chucking it down, and it has sprung a leak :ohmy: never had water leaking in the hanger before even in the very heavy thunder storms
The thing is it is straight on top of my drawing :S and has destroyed it :sick:
Think I must have been a very bad boy in a previous life to deserve all this shit :angry:
My block chopper
Onwards and upwards,
still no crying smiley Mike
Last edit: 22 Dec 2016 07:36 by THE BLACKBIRD.
Thanks: Klipkopwildlife, Quorneng, boz, Kintosh
22 Dec 2016 17:41 #15 by Klipkopwildlife
Replied by Klipkopwildlife on topic Own design and build sports turbine jet
I've never known a corrugated flat roof that didn't leak BB! I'm sure you'll be able to salvage your plans once they've dried out a bit, the important thing is not to pull them about too much until they're completely dry!
Time to create page: 1.057 seconds
