- Thank you received: 14470
- Thank you received: 10844
With what has happened to you Tony, I am not surprised. A lesser man wouldnt have got out of his bed, however, thats not either your or my style mate. Keep fighting , its the only way we know
- boz
- Thank you received: 1420
then I could not stand doing nothing so went to the hanger
I need a bigger shed the Buck spent the night outside along with the OD jet fuse as im trying to make room for more model storage never been a problem before as I always crashed them :ohmy:
glassed the top and bottom of the wing
Then built the first half of the tail feathers
Started on the opposite side
Need to go to rest
Got the other half of the tail built and the blue foam tips stuck on
So thought I would get them mounted
Then I started the fairing where they fit to the fuselage I glued it on
Then I thought mistake :ohmy: it would make it very difficult to get the part parted when I do the glassing, but it would not come off, in the end I had to resort to heavy instrument
Had to clout it 2/3 times with the obvious result
all filled in now, then I started the patterns for the fence round the fuselage
- Si_B
- Thank you received: 680
Looks good.
Simon
Made the elevators and hinged them ( dry fit )
And carved the fairing where the tail fits to the fuselage
I will fix it to the tail plane, then when I have made the fuselage I will fix the tail plane to it as a permanent fit
The canopy for the Revolver is ready to make the mould tomorrow, it has had 12 coats of polish and 4 coats of release agent
Making some racking to store models they are all big and take up a lot of room
I was going to use 25mm wood dowel to sit the planes on until I saw the price £12 for two Meters :ohmy:
So used some plastic pipe I had kicking about, I will replace it later
I can get two more models behind the tool bench
Got the other tail fairing carved
And that's all I have done today
That's all? [badass]
- boz
