07 Mar 2018 06:17 #106 by Mike Rolls
Replied by Mike Rolls on topic A Depron Airbus A350 - 1000 for 76 mm EDFs
Well done!!
07 Mar 2018 10:50 #107 by Mowerman
Replied by Mowerman on topic A Depron Airbus A350 - 1000 for 76 mm EDFs
Great job Simon well done.
08 Mar 2018 07:49 #108 by boz
Well done, what started as a maybe!! has come to fruition.enjoyed the build very much. :)
08 Mar 2018 17:04 #109 by one tenor
Replied by one tenor on topic A Depron Airbus A350 - 1000 for 76 mm EDFs
Terrific job . Very realistic.
10 Mar 2018 15:57 #110 by Ex-Member
Replied by Ex-Member on topic A Depron Airbus A350 - 1000 for 76 mm EDFs
Brilliant, well done Q - I'm pleased my concerns about the props turned out to be unfounded! ;) ;)
10 Mar 2018 21:21 #111 by Quorneng
Replied by Quorneng on topic A Depron Airbus A350 - 1000 for 76 mm EDFs
Thanks Andy
Surprisingly the props although a small diameter (3") are relatively quite a coarse pitch (3.5").
No so many model plane props have a pitch greater than their diameter. :P
11 Mar 2018 17:19 #112 by Mike Rolls
Used to be very common with rubber power. Back in the dark ages a very popular prop amongst Wakefield fliers was 18" diameter, 32" pitch, and many smaller models had props roughly pro rata.
Thanks: THE BLACKBIRD, boz
11 Mar 2018 20:36 - 11 Mar 2018 20:37 #113 by Quorneng
Yes Mike I should have qualified it as electric of IC direct drive model planes. ;)
Last edit: 11 Mar 2018 20:37 by Quorneng.
12 Mar 2018 02:06 #114 by one tenor
Quorneng wrote: Yes Mike I should have qualified it as electric of IC direct drive model planes. ;)
You've got me puzzled. Could you clarify this.
12 Mar 2018 07:46 #115 by Eric
I suspect either the cat walked over the keyboard, or the celebratory wine was doing the talking! [badass]
12 Mar 2018 11:14 #116 by Quorneng
"Yes Mike I should have qualified it as electric of IC direct drive model planes."
Just one letter wrong it should have be or rather than of - In my defence they are adjacent letters on the key board!
The reason for including 'direct drive' was that a geared motor can drive coarse pitch props similar to rubber.
12 May 2019 13:55 #117 by Quorneng
Ouch!
Nice weather this morning so I got out the A350 as it had not flown for quite a while - 9 months?
Everything worked no problem and there was virtually no wind at the field and some nice puffy clouds at altitude.
Of course when I actually launched it there was a significant puff of wind from the wrong direction so it went off down wind - I should have been more aware of likely gusts arising from those nice fluffy (thermal) clouds.
It did not gain sufficient flying speed, sank and dropped the right wing.
Broke off the nacelle and disrupted the wing spar.
The right nacelle itself also suffered.
In addition the whole front fuselage broke off but exactly at a construction joint so that will be just a simple glue job.
Not sure exactly how to repair the wing and nacelle but I don't think glue alone will do it!
The other aspect is the right wing tended to drop first anyway (significant right trim is shown in the model memory) so it really doesn't want to end up with any increase in weight.
Still if you can't risk it - don't fly it!
Thanks: Flytilbroke
12 May 2019 15:05 #118 by paul d
Replied by paul d on topic A Depron Airbus A350 - 1000 for 76 mm EDFs
Oh what a shame, lovely looking model..
Thanks: Flytilbroke
15 May 2019 12:18 #119 by Quorneng
It just so happens that when I made the A350 I printed and assembled (it has 9 pieces) a complete spare nacelle, not because I ever expected to use it but to shown what it looked like 'under the skin' and as an example for future reference.
Now part disassembled along side the damaged wing.
Note how tiny the fan/prop is!
There are two major problems
1. The motor wires are 'continuous' yet run inside the nacelle pylon and with nothing like enough 'slack' to make a join after the nacelle is in place.
Originally the wires were fixed to the motor first and then threaded thought the pylon, through wing and then soldered to the ESCs in the centre section under the fuselage.
2. The underside balsa wing spar has broken just inboard of the nacelle and the associated printed rib is internally seriously disrupted. On a wing where virtually all the loads are taken by the skin a simple rib replacement is not that easy.
It will take a bit of care not only to restore the strength to this very light structure but also to avoid building in any twist to what is a pretty high aspect ratio wing.
Hopefully it will all go back together. ;)
15 May 2019 21:59 #120 by Quorneng
The more seriously damaged wing underside showing the Depron replacement part wing rib and the carbon tow spar bandage.
Once the skin is replaced the wing should be as strong (well nearly!) as the original and the nacelle can start to be fixed on.
Thanks: Flytilbroke, Ralpharr2001
Time to create page: 1.794 seconds
