With the GP/NHS in the state it is it looks like I will get better before I even get to see the doc - but then that of course is the most 'efficient' solution! :woohoo
I am not knocking the NHS. It certainly worked for me to fully recover from a serious blood disorder, however in hind sight there were a number of "coincidences" along the way that just happened to fall into place not least by paying for a private hospital consultation. When I queried the doctor (he was also the local NHS hospital registrar) if he knew what was wrong he made the diagnosis "I can tell you are not well!" but I was in a bed at the NHS hospital within 3 hours!
Then it just so happened that an internationally recognised expert in what is a very rare disorder (12 cases per year in the UK) also happened to be a consultant surgeon at Manchester Royal Infirmary less than 20 miles away.
It could have all been so different.
- Thank you received: 14470
I've never mentioned it before - no need on here - but many years ago I contracted a weirdy disease, whilst out in the Far East. Symptoms like malaria, but it wasn't! As far as I know, it was never identified, but I was told not to give blood (for transfusions), as it might be passed on!
It hasn't flared up for several years, now, but when it does, I get the cold sweats, go dizzy, get the 'shakes', and feel like a deflated balloon for a few days after.
It used to be known as Wegener's diagnosis as he formally identified the symptoms in the 1930s but apparently his medical role in Nazi Germany during the war is now considered "questionable"!.
I have some very delicate paint lining to do on the nacelles along with some fine soldering, neither activity particularly compatible with coughing but everything is improving by the day.
- Mowerman
- Thank you received: 139
All the controls work in the correct sense and I think the stab functions are all correct as well but it is not so easy to jerk a big light plane enough to be absolutely sure of the gyro moves the surface in opposition.
Maiden will have to wait for ideal conditions - and the grass to be cut!
- Mowerman
- Squirrelnet
- Thank you received: 2067
- boz
- Thank you received: 1420
- Mowerman
A bigger 4S charged no problem so the fault is not with the charger.
The baffling bit is the voltages on each balance lead are correct. This only leaves that one or more of the sockets in the balance plug is not making proper contact with its pin.
A replacement 4s balance lead (x10!) is on order but of course it has to come from China.
A single UK sourced 4s balance lead costs twice as much!
Although the wind was very light its direction meant it was surprisingly 'bumpy' under the tree line. The stab kept things under control but it did not feel comfortable for a true low pass for the camera.
As can be seen it glides surprisingly well in fact the whole approach was power off. I held off for just a fraction too long and the right wing dropped (it always does) making the landing a bit untidy. No damage but I suspect if repeated too often something (an nacelle?) will give way.
- Reach
- Senior Member
- Thank you received: 28
