Avro Lancaster 102" Dambuster
  • Ralpharr2001
17 Aug 2019 18:12 #106 by Ralpharr2001
Replied by Ralpharr2001 on topic Avro Lancaster 102" Dambuster
A bit more done on the Lanc. Designed some air inlets and printed them. These are for the oil cooler on top of each nacelle. They are also on the engine cowling. So glued them on. To secure the battery cover I used the air inlet as a handle to slide the locking pin to secure the battery cover in place. Works well. No springs as im relying on the prop wash to keep it back in place.
Little bit of filling to do before paint but looks ok.
Slide the air inlet forwards and Lock open
slide the air inlet back and lock closed
Thanks: Klipkopwildlife, Flytilbroke, THE BLACKBIRD, crash happy
  • Ralpharr2001
21 Sep 2019 18:27 #107 by Ralpharr2001
Spent the last 4 weeks getting the paint on. Had a reaction to some filler i used so had the dig that out, refill, sand and prime. Painted it last weekend and left it until today to harden off. Not too bad. A few marks to touch up. So put the vinyl decals on that I cut using my Silhouette Cameo cutter. First time I've tried this. Had a bit of fun adding some weathering with the airbrush. Just got to put a coat of clear satin varnish over the whole thing then I can start fitting it out.
Thanks: Eric, Klipkopwildlife, Flytilbroke, Quorneng, THE BLACKBIRD, crash happy
21 Sep 2019 18:29 #108 by Quorneng
Replied by Quorneng on topic Avro Lancaster 102" Dambuster
That is pretty spectacular. Superb job.
Thanks: Ralpharr2001
21 Sep 2019 18:32 #109 by crash happy
Replied by crash happy on topic Avro Lancaster 102" Dambuster
Oh my that looks nice !:cheer:
21 Sep 2019 19:52 #110 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic Avro Lancaster 102" Dambuster
She looks great Ralph, a lovely job Sir
22 Sep 2019 08:42 #111 by paul d
Replied by paul d on topic Avro Lancaster 102" Dambuster
superb work Ralph!! the maiden can't be to far off now?
  • Ralpharr2001
23 Sep 2019 18:15 - 23 Sep 2019 18:17 #112 by Ralpharr2001
Not far away Paul. Probably another 3 or 4 weekends to finish things off. I hope the thing flies after all this work!
Did a bit of detailing as I was in the mood for it.
Fitted out the front turret, the guns do go up and down. Got to fit a small 5g servo below them to get them to go up and down. Probably link the servo to the elevator channel. Turret wont rotate though. :dry: Fitting the servo is a job for the future.
Guns down
Guns up
Finish painted the canopy, 4 evenings of masking up and 30 seconds of spray painting! Just got the tidy it up and its ready to fit. Couldn't resist placing it in position.
Just got to paint the pilot. Research on the correct colours is next then match up the correct model acrylics
Last edit: 23 Sep 2019 18:17 by Ralpharr2001.
Thanks: Klipkopwildlife, Flytilbroke, Quorneng, THE BLACKBIRD, paul d, crash happy
24 Sep 2019 18:11 #113 by crash happy
Ralph, how did you make all the "glass work" canopy ect ?
  • Ralpharr2001
25 Sep 2019 07:57 #114 by Ralpharr2001
Hi Crash,
I cheated!! Its a vacuum form. Fortunately the correct size was available for this plan, Sarik I believe. However, Vortex vacforms ( www.vortex-vacforms.co.uk ) make a lot of various canopies etc and show the sizes which helps.
I am building my own vacuum former but that's about item 8 on my list of things to do.
  • Ralpharr2001
28 Sep 2019 15:20 #115 by Ralpharr2001
Finish painted 'Guy' and glued him into his seat. Applied the satin varnish coat all over the fuselage and wings. Just let that dry and I can start fitting it out.
Thanks: Quorneng, crash happy
28 Sep 2019 17:35 #116 by Eric
Replied by Eric on topic Avro Lancaster 102" Dambuster
Is that Guy, or Doug Bader? :P
Thanks: crash happy
  • Ralpharr2001
28 Sep 2019 18:54 #117 by Ralpharr2001
:lol: :lol: :lol: :lol:
28 Sep 2019 19:11 #118 by crash happy
Well someone had to say it ! :lol:
  • Ralpharr2001
29 Sep 2019 20:09 #119 by Ralpharr2001
Question for you clever people out there. I have two left and two right hand rotating props to reduce engine torque. But which way should they rotate? Engines rotating towards the fuselage or away from the fuselage? :S My Mosquito the props rotates towards the fuselage but I don't know why.
Does it matter?:S :S
The full size has them all rotating anti clockwise (looking at the props from the front of the aircraft looking back).
29 Sep 2019 21:18 #120 by old fart
Replied by old fart on topic Avro Lancaster 102" Dambuster
I can't see it making any difference.
Time to create page: 0.842 seconds
