Avro Lancaster 102" Dambuster
29 Sep 2019 23:09 - 29 Sep 2019 23:13 #121 by Quorneng
Replied by Quorneng on topic Avro Lancaster 102" Dambuster
I does make a difference although a bit less in a 'four'.
Over the top towards the fuselage means that in the case of an engine failure the torque of the good engine(s) will tend to lift the wing of the failed engine making it that much easier (less rudder and aileron) to maintain 'straight and level'.
Obviously with a 'four' a single engine failure is less serious than with a high powered twin like the Mosquito but model planes do have a rather higher power to weight ratio than their full size counterparts. ;)
The classic example was the P38.
For stability reasons the props rotated 'over the top away' (unlike the prototype) so an engine failure on take off had serious consequences resulting in many deaths from an uncontrollable roll into the ground. The solution developed by the test pilots was to train pilots to instantly reduce the throttle significantly on the good engine, stop climbing and fly very carefully until the speed had built up to the safe single engine manoeuvring speed. Wow!
Last edit: 29 Sep 2019 23:13 by Quorneng.
  • Ralpharr2001
30 Sep 2019 19:01 #122 by Ralpharr2001
Replied by Ralpharr2001 on topic Avro Lancaster 102" Dambuster
Thanks for that explanation Q. Makes a lot of sense. So motors and props will be set to rotate inwards towards the fuselage.
Got away from work early today and fitted the undercarriage and aileron servos. Did a quick weigh in of every part and it comes out at an AUW (flying weight) of 6.34kg. As my target weight was 6.5kg i'm quite happy with that. If I need to reduce weight I can always chop a bit more off Guy's (Douglas's??) legs!! :woohoo: :woohoo:
Thanks: THE BLACKBIRD, crash happy
30 Sep 2019 20:39 #123 by Eric
Replied by Eric on topic Avro Lancaster 102" Dambuster
Teaching Granny - don't forget if you have all props rotating top inwards, you need two left-handed props and two right-handed! :P
01 Oct 2019 10:27 #124 by Klipkopwildlife
Replied by Klipkopwildlife on topic Avro Lancaster 102" Dambuster
Post #119, do keep up Eric![badass]
01 Oct 2019 10:37 #125 by Eric
I am keeping up - it's just that everyone else is running faster! [badass]
02 Oct 2019 09:24 #126 by Flytilbroke
Replied by Flytilbroke on topic Avro Lancaster 102" Dambuster
The "coiling" or rolling air when when passing the the tail in particular will have some control effect when Props rotating inwards. Outward rotation will possibly have a different effect. Look at the full size P38 for info. When counter rotating engines used it was good. the GB used same rotation for both and it performed less well.
02 Oct 2019 09:24 #127 by Flytilbroke
Thanks: crash happy
02 Oct 2019 17:55 #128 by Quorneng
To be fair the British P38s also had the turbo super chargers removed. The US were not at war in 1941 so they banned the export the 'classified' turbo charger, so it became a low altitude fighter a role for which it was really unsuited having been specifically designed as a high altitude interceptor.
Thanks: crash happy
02 Oct 2019 18:15 #129 by crash happy
Replied by crash happy on topic Avro Lancaster 102" Dambuster
I think a lot of it was also down to production & ease of parts & replacement engines, wasn't it ?
  • Ralpharr2001
05 Oct 2019 18:08 #130 by Ralpharr2001
Had a bit of fun this afternoon after flying this morning. Finished off the cockpit. Managed to find a map on the internet and scaled it down printed it then sprayed it in three coats for clear lacquer. Did the same for the navigation slide rule. Stuck them onto the navigators table behind the pilot. Fitted the engineers panel and seat in the stowed position. Ready to glue the canopy on tomorrow.
Thanks: Klipkopwildlife, Flytilbroke, Quorneng, THE BLACKBIRD, Fly-Navy, crash happy
06 Oct 2019 00:11 #131 by Fly-Navy
Replied by Fly-Navy on topic Avro Lancaster 102" Dambuster
Loving the build Ralph and your usual standard of workmanship. Are we continuing with the Firefly after this? Pretty please.
06 Oct 2019 00:54 #132 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic Avro Lancaster 102" Dambuster
And the Gannet
  • Ralpharr2001
06 Oct 2019 07:26 #133 by Ralpharr2001
Yes Firefly will be next. Got the cowling and canopy coming from USA at last. Taken nearly 2 years to get them due to production issues by the supplier. I will also be cracking on with the Gannet.
Thanks: Fly-Navy
  • Ralpharr2001
08 Oct 2019 22:22 #134 by Ralpharr2001
Firefly parts arrived from the USA today. So thats my winter build sorted. Should keep Fly-navy happy! :lol: :lol:
Thanks: crash happy
  • Ralpharr2001
11 Nov 2019 16:56 - 11 Nov 2019 16:57 #135 by Ralpharr2001
CofG sorted. Needed a little nose weight so i've decided to use 2200 3S lipo for the sound system and a 3200 4S via a separate switching BEC for the radio gear. Balances nicely with these in the nose and I have comfort that there is plenty of amps for the systems.
No photos unfortunately as not a lot to see. If the weather holds out at the weekend I might make a few taxi trial runs.
Last edit: 11 Nov 2019 16:57 by Ralpharr2001.
Thanks: Eric, Flytilbroke, crash happy
Time to create page: 1.029 seconds
