Just Junior
With no space now to store a large model I thought a just junior may fit the bill , it's a 75% scale model of the original 1946 J60.
After getting the plan printed via outerzone ( such a great resource) I've put scalpel to balsa and made a start on the fuselage.
Also began gathering a few bits and bobs needed further down the build, with genuine "airwheels" being ridiculously expensive now I've bought a pair of 3" du-bro wheels and tyres that I will make aluminium hub caps for to replicate the originals, also discovered that despite solarfilm products being discontinued you can still get the whole range from solarfilm direct, litespan in my opinion is without doubt the best lightweight covering ever made.
further posts as I make progress, and no before you ask it won't be powered by electrickery......
- crash happy
- Thank you received: 1203
I've got a box of elastic bands you can have ? Just saying.
cowl next then a bloody good sanding..
Tonight I'm going to try building the fin using a steamed strip.
- Thank you received: 10842
Surely you didn't expect a electric motor?THE BLACKBIRD wrote: Blimey its a diesel
However I have sorted out the servo tray, had to have it quite high up in order to keep the control runs reasonably straight ( throttle cable and closed loop for the rudder particularly) obviously the tank position is critical, needs to be on the CoG and in line with the needle valve, this has meant clearance above the servos is tight and it will need a yet to be made removable tray to sit on.
Hacked the cowling in order to clear the motor and that's about it....
You don't need reminding to liberally apply fuel-proofer all over the engine bay, before you bolt the PAW in, do you?
I have said "thank you" to each of your pictorial posts and that means I have positively looked at them.
Your work is of such high quality it there is very little I can comment on!
- crash happy
What do you mean " some expanded polystyrene THING ! :huh: I am mortally wounded & you are off my Christmas card list !
I have to say (grudgingly ) it is looking very nice though.
