- Thank you received: 10844
Unpacking proved ok, the moulded parts look good
Some of the plywood sheets with the laser cutting were badly twisted, so iv dipped them in the water but and weighted them down on the bench
So i suppose when i lift them off they will be stuck to the plasterboard
the rest of the wood looks good
The plan sheets are 3M long and 1M wide and come in 2 sheets to be joined together, so ill be cutting them up into manageable bits
started by cutting some pine blocks and screwing them to the bench on carefully marked distances
Then screwing the formers to the blocks
dont know if that is the way its done,
Then added all the stringers
Ill get around the missing former with some bracing, the fuselage is all sheeted anyway
The missing part are not even shown on the plan, not good
On the plan it has a one piece wing with half the fuselage fixed to it, even more than the Mossi builds, i dont like that so its getting a 2 piece wing with wing tubes, much stronger
- Thank you received: 14473
I'm guessing - but I'd start at a glow 2stroke 61 on each side?
With 61 two stroke the prop at best will be a 13x7.
At 20 lbs your are could aim for 100W/lb which gives 2000W say 3hp or1.5hp per side.
If you are going for petrol (4 stroke?) it might be hard to get sufficient power from a single cylinder and keep within the cowling
I have built it 3" longer than it should be, F___KING HELL
Now iv got to pick it all apart
Where's the crying mojo when you want one
Not much pleasure at the moment though picking it apart, managed to stab the scalpel in my finger so its getting painted red
Back on the slabbing today
Iv managed to get it all back together now, i had started the marking out at the wrong spot, such a stupid school boy error, and in the morning i have to take up the slabs i laid today as iv spotted another bloody error iv made today, old age sucks
I soaked the china ply sarick supplied for the engine formers in the water tube last night and used 2 slabs to press it flat overnight
Glue one together
