- Thank you received: 10844
- Thank you received: 14470
I spent 11 hours yesterday fitting the aileron and making the 2 flaps and fitting them, with the servos
Today i was going to do the other wing as i had already a while ago done the aileron and fit one of the flaps so just needed to hinge and connect to the servo, only to find that the flaps was for the other wing that i spent all day yesterday making new flaps for
I was so pissed off that i decided the wing was not good enough on the trailing edge so i took my frustration out on it and ripped all the rear of the wing off and did it all again
And started 2 new flaps
Much happier with the wing now
If it is higher, reduce the diameter of the prop some more.
Remember you can run an ESC using just a servo tester so avoiding the radio altogether. Simple, I do it regularly to test a motor before installation.
The knob on the servo tester sends a full min to max range signal so it will always run an ESC.
Of course you will have to calibrate the ESC with the radio before you actually fly.
I was only showing the servo tester to ESC connection.
according to the instructions its the thermal cut out thats doing it, but its only a 3s lipo and it rated up to 8
The original model had 2 pushrods to the elevators because of the dihedral on the tailplane so iv come up with something else
A bit of silver soldering
The attached a 3mm carbon tube pushrod to the servo
Seriously - the two tubes will be very weak at the 90' bends, and you have no adjustment for surface travel, other than at the servo end.
And, regarding the motors cutting out, do you have a Wattmeter in line, to see how much power they are drawing? Without that, you are just guessing. You cannot set up an electric power pack 'by ear', unlike an i/c engine.
Remember, the speed controller HAS to be able to deliver more power than the motor wants, or it overheats.
Disregarding the weight and bulk of the speed controller, it HAS to be bigger than the motor can demand at full power - the bigger the better. It doesn't matter if it is TOO big, as the motor will only take as much power as it needs to reach it's designed rpm's. (the kV on the label - rpm's per volt)
So if you have a 50 amp motor, and a 100 amp controller, everything is happy - - but turn it around and have a 100 amp motor, if the controller can only deliver 50, it will fry itself.
But it shut down as soon as the throttle reached halfway straight from stop, so it was still cold and only on a 3s lipo
Just getting a bleep bleep bleep bleep bleep bleep which according to the fault finder means the thermal cut out activated
