02 Jun 2026 09:33 #106 by THE BLACKBIRD
It often says duplicate message sent when iv only pressed the submit button once ? must have sent it twice that time
Thanks: Eric, Flytilbroke
03 Jun 2026 21:21 #107 by THE BLACKBIRD
I got the planking all done
So i thought i would have a break from the wings as i seem to have been building them forever, so much work in them
So i got the tailplane drawing on the bench and started it, again a lot of building in it, seem you have to build it in 4 halves and then glue them together then join the 2 together with the dihedral
03 Jun 2026 21:30 #108 by Eric
That could be a challenge!
04 Jun 2026 13:08 #109 by THE BLACKBIRD
No the tailplane is built in 2 separate parts one each side and each side is built in 2 separate pieces then glued together, then the parts from each side is glued together making a whole piece thats then built onto the fuselage
04 Jun 2026 16:14 #110 by Eric
You missed the joke, BB - four halves!
05 Jun 2026 09:38 #111 by THE BLACKBIRD
No i saw the joke Eric, a Murry Walker type joke with half the race gone theres half to go, i was just pointing out the amount of building
seems a hard way to get a complete result
05 Jun 2026 10:08 #112 by THE BLACKBIRD
As you can see not much done today just 4 of the halves   of the 8 that make up the tailplane
05 Jun 2026 17:52 #113 by THE BLACKBIRD
slow progress
06 Jun 2026 18:10 - 06 Jun 2026 18:24 #114 by THE BLACKBIRD
Run into a problem having built it to the plan i find the cowl will not fit over the planking, iv sanded the 3mm planking down to a point it cannot sand anymore so it looks like its a pull apart job
Lot of dihedral on the tail
Trying to come up with a hinge that i can take apart
i notice this threads had 1235 views so there must be a lot of people looking in on the forum and not joining us, shame really as we could use some new blood on here
Last edit: 06 Jun 2026 18:24 by THE BLACKBIRD.
07 Jun 2026 20:12 #115 by THE BLACKBIRD
I rebated the 2mm sheeting on the tailplane 1mm so that i could glue a 12mm wide piece of proskin along the edge to act as a cover for the elevator / tailplane joint
Did some pulling apart where the cowling fits
It now fits in the correct distance from the wing
Dont think it needs re sheeting as its only seen with the cowls off
Thanks: Eric, Klipkopwildlife, Flytilbroke, Quorneng, Ralpharr2001, jon.in.swansea
08 Jun 2026 15:21 #116 by THE BLACKBIRD
Just been looking at some pics of this and looking at the plastic model i have and the elevator and ruder look like they are covered in cloth or they have external ribs, iv already sheeted the top side of the elevators, anybody got information on this
08 Jun 2026 18:25 #117 by Quorneng
Replied by Quorneng on topic A nice sized Bristol Beaufighter
BB
A quick Google search revealed this which gives the actual construction details.
"The tailplane unit of the Bristol Beaufighter featured a hybrid structural construction. While the main horizontal stabilizers and vertical fin were all-metal structures finished with a smooth, flush-riveted skin, the tips of the tailplane were uniquely made of wood. url=https://www.britishaviation-ptp.com/Companies/B/bristol_156.html]1[/url
Furthermore, all of the actual flying control surfaces on the empennage—including the elevators and the rudder—were metal-framed but entirely covered in treated fabric."
The fabric covering of the elevator and rudder are replicated in the bigger scale plastic kits.
I hope this helps
08 Jun 2026 18:35 #118 by THE BLACKBIRD
Thanks Simon iv sheeted them now as they would be very flimsy as built, just have to try and make them look cloth covered somehow
09 Jun 2026 10:37 #119 by THE BLACKBIRD
The sheeted tail
And doing a little more on the gear doors
Im going to have to make two plugs as they are not the same shape, sort of a left and a right hand, thats a lot of extra work
13 Jun 2026 18:39 #120 by THE BLACKBIRD
Done a little bit more on the fin and tailplane
Time to create page: 2.318 seconds
