07 May 2026 17:16 #61 by Klipkopwildlife
Replied by Klipkopwildlife on topic A nice sized Bristol Beaufighter
I find it difficult to get my head around that Tony, you were in so much pain when you were here, I just cannot get my head around it being worse. I wish I could take over some of the pain for you.
Thanks: Eric, THE BLACKBIRD
08 May 2026 05:45 #62 by THE BLACKBIRD
The problem with my neck started in 1997 and has gradually got worse over the years, falling of the villa roof in Cyprus and breaking my neck in 2 places has not helped,
But this last year has seen a dramatic increase in the pain and it has spread to all my neck and back of my head, and nothing helps it, iv got morphine the im supposed to take in small amounts but iv drank it straight out the bottle and no effect
i should have kept the neck brace i had in Cyprus but i was so please to be out of it i never kept it, just ordered a new one yesterday
08 May 2026 11:09 #63 by THE BLACKBIRD
I need to make a retracting steerable tailwheel for this model and it must be light weight
08 May 2026 23:53 #64 by THE BLACKBIRD
I was having a play around trying to make a main gear leg and i silver soldered the stainless steel tube, i will not use it as its heavy
10 May 2026 19:05 - 10 May 2026 19:06 #65 by THE BLACKBIRD
Still playing around with the landing gear, the limited tools dont help, God look at the bench, looks like Klipies
Loosely laid a plank on the side of the fuselage to see how the wing fits, its ok
And of course having a go at the retractable steerable tail wheel
And working on the aileron and flaps
Last edit: 10 May 2026 19:06 by THE BLACKBIRD.
Thanks: Eric, Klipkopwildlife, Flytilbroke, Quorneng, Ralpharr2001, jon.in.swansea
12 May 2026 20:49 - 13 May 2026 10:27 #66 by THE BLACKBIRD
I finished sheeting the underside of the wing and started the top
That done i finished the top sheeting and called it a day
Slowly slowly
Last edit: 13 May 2026 10:27 by Klipkopwildlife.
13 May 2026 06:32 #67 by THE BLACKBIRD
Two pictures not showing in the thread when i have inserted them, whys that
13 May 2026 06:54 - 13 May 2026 06:55 #68 by Eric
Did you press 'insert all'
I saw one full-size photo, one thumbnail of the sheeted wing, and one that was a blank square with an i in it!
Last edit: 13 May 2026 06:55 by Eric. Reason: typo
13 May 2026 12:23 #69 by THE BLACKBIRD
No i always press them individually
13 May 2026 21:21 #70 by THE BLACKBIRD
Had a mixed day got all the sheeting done and the leading edge on and sanded down  But the trailing edge is a very week design, no strength in it at all as i found out even though i had glued a strip of Proskin along to edge
So iv tried to glue a piece 50mm wide along the whole trailing edge
Adding weight in the wrong place but it was no good left, see how it turns out
13 May 2026 22:17 #71 by Ralpharr2001
Replied by Ralpharr2001 on topic A nice sized Bristol Beaufighter
That's a good idea BB of using flightskin to strengthen the trailing edge. I'll steal that idea and use it myself.  I usually glass a strip of 25g cloth to give it strength. But it does leave a poor surface finish that needs to be filled if the surface is visible.
Are you sure you are not going to fly this? It looks too good not to be flown. Go on you know you want to!!
14 May 2026 10:50 - 14 May 2026 10:53 #72 by THE BLACKBIRD
i cant fly as demonstrated in South Africa,
And anyway i think this will be the most expensive model iv ever built behind the £6500 SU 27
Last edit: 14 May 2026 10:53 by THE BLACKBIRD.
14 May 2026 20:25 #73 by THE BLACKBIRD
It set out to be a good day, i got the most slabs laid that i have done before the pain gets to bad and stops me
Then i mounted the tail wheel
I need some carbon tube to connect to the retract servo which iv fit under th cockpit as i was using some brass tube that i had and silver soldered M2 ends on it
But i set fire to the bloody fuselage in doing so
Also scorched the wire from the new servo i has just fitted for the tailwheel
15 May 2026 06:17 #74 by jon.in.swansea
Replied by jon.in.swansea on topic A nice sized Bristol Beaufighter
Ouch!
15 May 2026 06:34 #75 by Eric
Time to create page: 1.877 seconds
