3D printing Widgets
17 Mar 2022 07:15 #1 by Klipkopwildlife
3D printing Widgets was created by Klipkopwildlife
Jon has asked that we have a section where useful stuff can be uploaded for 3D printing, here it is.
17 Mar 2022 13:29 #2 by jon.in.swansea
Thanks Tony.
A suggested pattern for submissions might be:
a) a brief description
b) photo of the item in context of its use as well as a CAD view of the item
c) notes about printing
d) at a minimum the STL file
e) hopefully the CAD file (note these will likely need to be 'zip' files) and optionally notes about the CAD design
f) if contributor might answer questions or be amenable to tweak the CAD file for others.
Here is a device to secure motor cables - in a rough landing ESC, batteries, receivers can shift and drag wiring and disconnect motor wires. To save the faffing around out in the field I created a small device to secure the bayonet connections. It uses a rubber O ring to hold the bayonets in place.
In freeCAD I started with a main block and then cut away unneeded sections (hence the many 'cut' entities). I then added 4 separator blocks in the centre.
Typical printing settings are 2 perimeters, 10% infil, 2 layers top and bottom. Adapting the axis scaling would likely be all you would need to tweak it for different connector sizes.
Below is a photo of the device (normally Velcro'd to the fuselage wall) , what it looks like in freeCAD and the STL and CAD file (compressed).
Enjoy... I will await comments/suggestions prior to uploading more items.....
17 Mar 2022 16:26 #3 by Klipkopwildlife
Works for me Jon, on many foamies the nose is so tight around the motor that the wires commonly rub on the outer casing giving inconsistent motor running and blowing the ESC in some cases. Having the ability to hold the bullet connectors firmly will be a definite plus.:)
Thanks: jon.in.swansea
17 Mar 2022 18:28 #4 by paul d
Replied by paul d on topic 3D printing Widgets
All very clever but if the running gear is installed correctly in the first place then wires etc shouldn't chaff, tie wraps have always worked for me.
17 Mar 2022 19:54 #5 by Eric
It depends on how the motor is installed - if the fixed portion is in front of the bell (the spinny bit) then the wires HAVE to be shielded from chafing.
I lost a new model like that, years ago, I hadn't realized that the motor was one of those silly little things that clamp into a top-hat that is bolted to the firewall. I'd read that the screws weren't very tight, so needed nipping up before flight, so I had done - but unfortunately the wrong screws! The motor, under load, rotated the opposite way to the prop until it had taken up all the slack in the three wires, burned through them, and shorted the speedo. The resulting detonation of the FET's blew a hole in the grp fuz! The burning remnants crashed to earth over the far side of the filed, and had pretty much burned out before I could get to it!
The mobile hangar stunk for weeks, after I'd put the remnants in to take home!
Further investigation showed that there was only one grubscrew in the top-hat mount, as well, instead of two.
18 Mar 2022 07:29 #6 by Klipkopwildlife
Multiplex Fun Cub, Mentor and Blizzard all have the same problem, the rotor is behind the motor mount and there's very little room for the wires to pass. A widjet such as Jons would save a lot of grief glued on the floor or roof of the cowl. Shoving a zip tie through the fuselage wasn't an option for me.
For me, putting the heavy rotor behind the mount with the propeller in front reduces any gyroscopic effect there might be, if any.
Thanks: Eric, jon.in.swansea
18 Mar 2022 21:19 #7 by jon.in.swansea
The thing I forgot to mention about the motor wire keeper is that it keeps the bayonet(s) from touching. Where the heat-shrink might have gaps or the bayonets not fully seated I imagined that a short could cause damage to the ESC or a loss of motor control.
18 Mar 2022 21:38 #8 by jon.in.swansea
Here is another collection of useful bits. I got tired of messing up foam wings gluing on popsicle sticks to limit damage from rubber bands. Trailing edges are generally simple shapes but leading edges not so much. The foam ARMIN wings I wanted to protect have a complex leading edge so I had to learn some new CAD skills to replicate the actual section. It would be a similar process to create on for a Clarke-Y and probably easier because I know now how to trace a poly line over the ribs I have been working on.
Rather than lots of separate images pasted into the chat I created a couple of montages. Less space, words closer to images. The freeCAD and STL files follow the montages. Enjoy. -Jon
19 Mar 2022 00:17 - 19 Mar 2022 00:20 #9 by Quorneng
I did the same sort of printed protection for the rear of the Big Dragon wing with an included angle of 6 degree for the dihedral.
The front protection was a bit more complex as it could not be printed the same way in one piece so the halves were printed individually and angled by 3 degrees to the printer bed and then super glued together.
The front protection covered the top surface back 50 mm but also supported the leading edge profile. The rear covered 30 mm top and bottom. I judged the Depron surface in between would not suffer from the retaining bands.
Both covers matched the printed rib section but were adjusted for the thickness of the Depron skin.
More describing the principles involved but the stl files are available. Just give us a shout. ;)
Last edit: 19 Mar 2022 00:20 by Quorneng.
19 Mar 2022 07:13 #10 by Klipkopwildlife
Liking this, all useful stuff.
19 Mar 2022 08:26 #11 by paul d
Like it, what a good idea.
19 Mar 2022 11:12 #12 by Quorneng
Just in case anybody is puzzled by the front wing cover being narrower than the rear it is simply the wing has a 3 point hold down with a single hook at the front.
Such a narrow hold down is not ideal but was deemed acceptable in this case as the wing mount on the top of the wing pylon is quite narrow anyway.
19 Mar 2022 12:09 #13 by jon.in.swansea
I see several of us have co-evolved similar devices - the trailing edge designs being quite similar while the leading edge involving different printing paths to a similar end. It was fun designing these widgets and even more fun to have a 'library' of bits so as to pick up and run with good ideas within the community.
Getting the files together for submission also encouraged me to tidy up the naming of the CAD entities as well as tweaking the thickness in the sketch for the leading edge so as to generate a more robust part. -Jon
20 Mar 2022 10:22 #14 by jon.in.swansea
Sometimes not having the tool-for-the-job is so frustrating. I had what might have been a good flying session with my straight wing Franken pod and a test of my new head-mount rig. Clear and not-so-much-wind but the grass was quite muddy in places. The beastie is rather twitchy and I had not used it in some time so I had not yet gotten it tuned in and my initial landing happened to coincide with more mud than grass.
Yuck, no way it is going to clean up in the field. Take it back, clean and dry. And when re-mounting the motor I fumbled over and over with getting the nuts and bolts in place. Argh! What I need is something better than my finger and better suited to the task than long pliers.
So here is my latest widget - there are two variants within the freeCAD and STLs. Should be adaptable if you get out your callipers and tweak the radius of the regular polygon and the shaft. -Jon
21 Mar 2022 09:57 #15 by Klipkopwildlife
Jon said, "The beastie is rather twitchy and I had not used it in some time"
Have you thought of trying Exponential? I use it all the time, 30% to 50% it just softens the centre point nicely while still giving you full throw.
Time to create page: 1.138 seconds
