- Thank you received: 14470
3D printing Widgets
I don't know about print filaments, I don't know what will bond to it.
I looked it up on my browser, but cannot find that particular glue. The nearest one is in 20 mil tubes for about £4, and looks like it has rather nasty properties.
Danger!
Causes skin irritation. May cause an allergic skin reaction. Causes serious eye irritation. Harmful if inhaled. May cause allergy or asthma symptoms or breathing difficulties if inhaled. May cause respiratory irritation. Keep out of reach of children. IF INHALED: Remove person to fresh air and keep comfortable for breathing. IF IN EYES: Rinse cautiously with water for several minutes. Remove contact lenses, if present and easy to do. Continue rinsing.
It says it dries with a yellowish colouring. TECHNICQLL R-167 Universal Adhesive -30 / 80, Heat-resistant, light yellow, Capacity: 20ml Article number: R-167 EAN: TCHR-167
Is this the same one? If not, what is your source?
- jon.in.swansea
- Thank you received: 1192
The latest just last week from an ebay store called VOYTO.
An ebay search "VOYTO Technicqll" will find it directly.
Technicqll do a range of different glues but for "foam safe" it has to be "Polyvinyl Adhesive" in the yellow and white 70ml tube.
I have bought a dozen or more over the years all from Ebay and post free!
- jon.in.swansea
The first trial with a truncated cone failed to split apart the STL file. A bit of lateral thinking created a solid body to use with a boolean cut to produce a variant STL that proved to be a good fit. Hope that these notes might inspire others to adapt if you find a mismatch!
And, within reason, I would be happy to look at Aeromodeller's STL parts that might work better if tweaked - no guarantee that getting a better fit might be possible given the many corners of FreeCAD I don't touch.
As usual, probably easier to see the tweaking process when viewed on YouTube rather than the thumbnail on the Aeromodellers web site.
- Magpie
- Thank you received: 1048
I have just tried to attach my file but because FreeCAD has saved it as an .FCStd it won't attach. So I need to find out how to save it as an .STL
- Magpie
Jon should be able to give you a link to a guy that uses the latest version of Fcad, it's a waste of time using anybody elses.
I think you will find that such files are not recognised directly by this site but can be down loaded.
This is a screen shot of your stl file down loaded from this site and onto my Free Cad.
So it works!
In Free Cad you do have to "Edit, Select All and Export" to create an Stl. The Stl is stored as a new file which not directly editable in FreeCad.
Note. As long as you have given the Stl exactly the same name as the original FCstd file both are stored adjacent to each other in the Free Cad file list.
Once you are looking at the Stl file in Free Cad you have to go back and open the original FCstd file to make any changes.
If you do modify the FCstd file remember to "Edit, Select All and Export as Stl" or the changes you have made won't appear in the Stl. It is one of the drawbacks of the file structure in Free Cad.
- Magpie
My main difficulty is adding the constraints, they seem to have a mind of their own and I cannot find some things like copying & mirroring.
The aim is to stick it onto some polystyrene & then onto my test rig arm so as to reduce the vibration.
The LE2204 has got me frightened!
I am not sure a piece of polystyrene will solve everything if the vibration is severe.
To be honest if it were me I would simply mount it rigidly on a piece of wood I could hold in my hand. The human hand makes a wonderful shock absorber and the LE2204 is a pretty small motor. Just be prepared to stop if you think it is getting to the point you can't hold it.
In the past I have have hand held an ED 246 Racer diesel fixed to a piece of wood and finger "flick" started it using the other hand.
Of course as a youth you are convinced of your indestructibility!
