- Thank you received: 14470
3D printing Widgets
- jon.in.swansea
- Thank you received: 1192
Up is greater than down angle. Also, the epoxy'd the new servo arm extension is used in the video.
Have a look at this 10s video. If it looks good enough I can finish the joins and get on with gluing the upper skin.... -Jon
Some people prefer to use 'rates', which gives you a high and low (adjustable) setting - the disadvantage is, you have to remember which switch you used to select that - when you have a panic moment!
There is no switch to select with expo, it is there all the time!
- Oily
- New Member
- Thank you received: 23
I’m also building a Voron Trident printer with a 300mm x 300mm x 300mm volume so I can print ABS parts etc if anyone needs anything printed in ABS
Just sorting out the wiring at the moment
- jon.in.swansea
I managed to get the down angle to be quite minimal while retaining the up angle. As far as I can tell the response has improved (within a limited set of flight tests).
Now I just have to replace the ESC (the T30 connector is failing) until I can re-solder the old ESC....
- jon.in.swansea
- jon.in.swansea
Occasionally I have wanted a bigger build volume - but the mini does take minimal space and it has forced me to be clever on the CAD designs. This ability to 'think of a thing and then make it real is the core of the fun of printers..."
Never tried ABS which would be a stretch on the Prusa with no enclosure. PLA has sufficed for my needs thus far.
Bravo that you are offering to help folk print stuff!
You know that STL files can be shared on the site. But not yet freeCAD files (unless they are zipped). -Jon
This is the result, yes so what? I here you saying, I printed them in ABS! And they haven't pulled off the build platform.
At that thickness you stand a chance but thicker items always bend unless the whole printer is in a hot box and the finished print allowed to cool uniformly.. .
