Auster mk5
need to work out how to make it now.
- Thank you received: 14473
Something similar was made commercially, but I've not seen it for a long time.
ps - I missed off that the two ellipses are slots, one up and down in the fixed portion, and one angled in the slider.
The only problem is those types of hinge work at a low mechanical advantage so there is comparatively little rod movement thus requiring high forces from the servo.
if they are ok, i will use them for the flaps and then have a re think about the ailerons.
started making the ailerons today, but not got very far with them.
building them scale was not going to work.
so i went back to the old method.
solid sheet center section with half ribs.
wont be seen when covered will it.
got to wait and see if these hinge horns i ordered are any good before i can go any further with them.
spent an age bending wire to make the roof wires, not sure if they are right though.
they look fairly close to the pics i have, i take it the plastic roof panel does not touch them.
if they are ok, i will glue them in tomorrow ans then solder thee center together.
will have to make the trim tab winder to got there as well.
remind me next time to build something less complicated.
i plan to run wire down each upright from the wing rods down under the floor to give some more strength to the cabin area.
then we have the rear wire supports and the front glazing bars.
once all this lot is done the whole cabin area will be massively stronger than it is now, though i cant pull the wing supports off the fuselage at the moment anyway.
the glazing will be fun, lots of curved plastic needs to be formed.
