avro shackleton mk111
A force that is equivalent to a significant proportion of the planes weight?
The full size managed with just 'arm' power - a force that would be equivalent to only a tiny proportion of the planes weight.
For my money 4.5kg should be more than ample unless too much is lost due to inefficient linkages and hinges..
saves me having to seriously butcher the tailplanes about to fit standard servo's phew.
fins gluing on.
next job is to finish sheeting the tail end of the fuselage, sand to shape and then i can fit the tailplane. fingers crossed
then i sat for ages sanding the fuselage smoother.
then i cleared the conservatory a bit and laid the shackleton all out on the floor.
fitted the wings, jigged it all up square and stuck the tailplanes on.
even though it looks wrong, the fins are vertical, cos i set them with a square.
needs sanding tomorrow.
- Monz
- Monz
need to find the right grey for the tops of the elevators.
if i get time tomorrow i want to cover the fins and tailplane ready for some paint as well.
so to bed it has gone.
- Monz
