A W Ensign
20 Dec 2016 22:18 #106 by Mike Rolls
Replied by Mike Rolls on topic A W Ensign
Looks very smart, Tony
20 Dec 2016 23:08 #107 by one tenor
Replied by one tenor on topic A W Ensign
Terrific job Tony
21 Dec 2016 18:17 #108 by boz
Replied by boz on topic A W Ensign
Great job
22 Dec 2016 02:47 #109 by one tenor
A Super Connie next maybe ??????
24 Dec 2016 15:42 #110 by Ex-Member
Replied by Ex-Member on topic A W Ensign
still painting the main wing.
got the outer panels to cover and paint, then the u/c. still we are getting there.
we will be back onto this after Christmas now.
Have a Merry Christmas and a Happy new year.
28 Dec 2016 17:42 #111 by Ex-Member
Started sealing the main fuselage and wing centre section today.
two coats of sealer done and one to go.
I have jut got to finish the outer wing panels and make the u/c and we will be finished.
phew
29 Dec 2016 21:00 #112 by Ex-Member
No pictures today.
I have finished sealing the main construction.
added the wing tips to the outer wing sections and started sanding them to shape.
tomorrow i hope to get them covered and ready for painting.
then it is just constructing the undercarriage and final fit out.
nearly there.
30 Dec 2016 16:48 #113 by Ex-Member
Well i have started covering the outer wing sections.
taking an age to dry as it is so cold.
we will plod on with this one.
30 Dec 2016 18:51 #114 by Quorneng
Replied by Quorneng on topic A W Ensign
Just an aside but it appears that in 1944 Echo had its tail wheel assembly replaced by one from a Lancaster as there were no more originals available.
Apparently it was 9" taller which made is sit at a shallower angle to the ground which noticeably increased the length of the landing run!
Thanks: Ex-Member, boz
30 Dec 2016 19:00 #115 by Garry Pollard
Replied by Garry Pollard on topic A W Ensign
Would that also affect the take off run Q ???
30 Dec 2016 21:14 #116 by Eric
Replied by Eric on topic A W Ensign
I should suspect so, Garry, as the pilot would not be able to get the tail down to the normal 'rotate' position! He'd have to 'sprint' it off! :P
30 Dec 2016 23:04 #117 by Quorneng
No mention was made about the take off run but apparently the Ensign's pneumatic brakes quickly drained the air reservoirs so getting the tail positively down created a high drag condition to help it slow down. The longer tail wheel reduced this effect.
To ensure there was sufficient air to finally stop at the required position taxiing was done using the inner engines and the elevators to lift the tail when required and the outers to steer.
It is not that surprising that the Ensigns flown "into the ground" over the war years as this was one of the routes they were used on.
www.rafkasfareet1953-56.com/uploads/5/5/...392/3595095_orig.jpg
A long range 'delivery' flight with overload tanks in the cabin to Takoradi and then 3000 miles hopping back and forth across equatorial Africa. A very different kind of flying from today!
Thanks: Garry Pollard, Ex-Member, boz
30 Dec 2016 23:18 #118 by Garry Pollard
Thanks for that Q, very interesting .
04 Jan 2017 16:34 #119 by Ex-Member
Finally finished painting and sealing the outer wing panels and ailerons.
still need to carve a nose block and make the undercarriage.
but it is getting there at last.
Thank you for watching.
04 Jan 2017 16:59 #120 by Kintosh
Replied by Kintosh on topic A W Ensign
Very nice job Tony
Bob
Time to create page: 1.730 seconds
