A W Ensign
06 Dec 2016 16:18 #91 by Ex-Member
Replied by Ex-Member on topic A W Ensign
Finished the markings today.
Need to tidy up and glaze the cockpit and then add panel lines. ( no rivets though)
not perfect but not too bad if viewed a distance. :P
07 Dec 2016 18:26 #92 by Ex-Member
Today i have managed to add the few panel lines that the model is having.
then i glazed the cockpit with some acetate sheet.
i need to add the outer glazing bars tomorrow.
then i can seal the fuselage paintwork and add the blue foam nose.
I need to get back onto the wing next week.
i must get the wing joining tubes sorted as this is holding me up now.
08 Dec 2016 14:28 #93 by Ex-Member
Started adding the outer frames to the cockpit windows last night.
wired up the replacement esc and we now have four working motors again.
ned to sort the wing tubes and i will be able to get this one finished off by the new year.
10 Dec 2016 17:03 #94 by Ex-Member
Well i have finished the glazing bars.
just need to carve the nose block now.
all the wing joining tubes are in and the outer sections slide on and off smoothly.
fitted the aileron servos and started sheeting the outer sections.
I need to look at the retracts tomorrow if i get time, then i can finish the wing sheeting and get covering.
we plod on.
11 Dec 2016 17:28 #95 by Ex-Member
Well i have got most of the wing sheeted today.
needs to be sanded and covered now and then i can build the centre section into the fuselage.
u/c next job this week.
nearly finished.
11 Dec 2016 21:10 #96 by Firewood
Replied by Firewood on topic A W Ensign
Nice work Tony your a clever man :) :)
12 Dec 2016 19:25 #97 by Ex-Member
Working on the underside of the centre section today.
blending in the nacelles today.
slowly getting nearer to the final covering and paint day.
13 Dec 2016 16:32 #98 by Ex-Member
Wing centre section getting glued home.
lets hope nothing moves while the glue is setting. :unsure:
13 Dec 2016 16:51 #99 by Mowerman
Replied by Mowerman on topic A W Ensign
I thought that was proof loading for the U/C
15 Dec 2016 16:52 #100 by Ex-Member
Been busy today building the wing to fuselage fairing today.
and finishing of the rears of the nacelles.
tomorrow i need to start sanding all the wing down to get it ready for covering.
17 Dec 2016 18:00 #101 by Ex-Member
Top of the wing sanded and the covering started.
Had two coats of sealer now, one more left to do.
then i can flip it over and cover the underside.
then we can paint the centre section and start sanding and covering the outer panels.
we plod on
18 Dec 2016 16:17 #102 by Ex-Member
top of the centre section painted.
hope to do the underside next week, then get on with covering and painting the outer sections.
18 Dec 2016 23:57 #103 by Fly-Navy
Replied by Fly-Navy on topic A W Ensign
What a lovely looking model Tony, what proper looking British a/c look like. Avro York next perchance? Spend ages around the one at Cosford when I visit.
Lets have some flying pics too sir. :kiss:
19 Dec 2016 17:35 #104 by Ex-Member
Started the markings on the top of the centre section today.
will mark up the other side tomorrow...i hope.
20 Dec 2016 21:24 #105 by Ex-Member
Still plodding on with the paint.
be worth it in the end i hope.
we plod on
Time to create page: 1.405 seconds
