A W Ensign
26 Oct 2016 17:50 #31 by Ex-Member
Replied by Ex-Member on topic A W Ensign
been painting on and off today.
to brilliant, but it will do me.
need to sort the floor colour out next and give the cream another coat.
want to glaze the windows tomorrow and then i can finally glue the fuselage halves together... i hope. :P
26 Oct 2016 19:03 #32 by Firewood
Replied by Firewood on topic A W Ensign
Looking fantastic Tony :)
26 Oct 2016 20:52 #33 by Eric
Replied by Eric on topic A W Ensign
And for your next challenge, Tony, how about one of these? -
forces.tv/74093164
[badass]
26 Oct 2016 22:40 #34 by Quorneng
Replied by Quorneng on topic A W Ensign
Just think of the pitch of those seats compared to "cattle" class of today!
27 Oct 2016 20:25 #35 by Ex-Member
finished the interior painting today.
glued the windows in.
curtains tomorrow and then the fuselage halves can be glued together.
29 Oct 2016 14:05 #36 by Ex-Member
Fuselage joined at last, jut waiting for it to dry.
seats all in.
curtains done.
a view through a window.
29 Oct 2016 16:40 #37 by Mike Rolls
Replied by Mike Rolls on topic A W Ensign
So where are the gin and tonics? Seriously - looks great
29 Oct 2016 17:47 #38 by Ex-Member
All i have got done today is to cut the tailplane core from 6mm grey depron.
maybe i will get it built tomorrow, if allowed. :angry:
30 Oct 2016 16:26 #39 by Ex-Member
Today i have constructed the tailplane and elevators.
6mm Depron core with a balsa spar and 3mm Depron skins.
it will go on about here once i have the fin constructed.
then i made a ladder and fitted it.
fin and rudder plan has been printed off and i hope to build it tomorrow.
byeeeeeeeeeeeeeee
31 Oct 2016 18:04 #40 by Ex-Member
Built the fin and rudder today.
Usual method of the 6mm Depron core with 6x3mm balsa spars and 6mm balsa hinge posts.
then skinned with 3mm Depron. sorted.
the spars extend beyond the fin so that they go through the tailplane and into the fuselage.
they then slide either side of the fuselage cores to hopefully make a strong joint, but time will tell.
so i plonked every thing in place and to me it looks just about great. :cheer:
I will not be gluing this lot on till after the model has been completely finished and covered.
so the next job is to start the main wing centre section. :)
31 Oct 2016 19:07 #41 by Flytilbroke
Replied by Flytilbroke on topic A W Ensign
Very nice Tony, you are just getting better all the time.
01 Nov 2016 16:17 #42 by Ex-Member
Today i managed to print out the wing plans and cut the wing cores out from 6mm Depron.
a nice big fat wing so it should fly nice and slowly.
if i finish it.
Need to design all the ribs and spars next.
the nacelles will be fun :P
02 Nov 2016 17:32 #43 by Ex-Member
The first of the spars have been designed and built.
If i feel better tomorrow and get the time i will design and build the rear spars and take a look at the wing joining tubes.
the centre section will have all the motors and retracts in, so i need to plan it all out slowly.
i would not want to miss anything once the wing has been sheeted. :P
03 Nov 2016 16:26 #44 by Ex-Member
Well today i designed the top rear spars and built them up.
Then i glued them in place.
After that i designed and cut out the trailing edge ribs, then glued them in place.
Finally i cut out and glued trailing edge sheet home.
As i need the wing joining tubes before i can go any further with the centre section, tomorrow i will make a start on the spars for the outer sections.
i might even get the ailerons made.
i will need to cut the wing opening a bit more to shape when i have the wing finished.
03 Nov 2016 16:46 #45 by martynk
Replied by martynk on topic A W Ensign
Looks great Tony..very nice indeed
Time to create page: 1.105 seconds
