Hints and Tips
  • Flytilbroke's Avatar
20 Feb 2015 22:03 - 20 Feb 2015 22:05 #16 by Flytilbroke
Replied by Flytilbroke on topic Hints and Tips
This for Andy's Tip re-hair clip..
Thank you for what they are called, I did not know, and for the reminder on how useful they are for light/fragile joints
Last edit: 20 Feb 2015 22:05 by Flytilbroke.
08 Sep 2015 08:53 #17 by Ex-Member
Replied by Ex-Member on topic Hints and Tips
I was searching the net this morning for some ideas on auto-rudder set up for Free Flight gliders when I came across this site. It didn't help me with the auto-rudder, but it's a mine of information on many free flight and scale subjects. Give it a try....but allow time to do so, there's probably over a hundred papers to indulge in:
The National Free Flight Society (of the USA) Technical Library:
freeflight.org/DigestOnline/library.htm
14 Sep 2015 23:01 #18 by one tenor
Replied by one tenor on topic Hints and Tips
If you are really frugal many of these types of lid can be flexed and the old epoxy peeled off .This goes for body fillers too
15 Sep 2015 00:13 #19 by one tenor
one tenor wrote: If you are really frugal many of these types of lid can be flexed and the old epoxy peeled off This goes for body fillers too
:evil: Damn I just almost finished an addition to this . Pressed the space bar and bingo it vanished. Right here goes again. Dope brushes can be kept soft and ready for us as follows. Take a jar with a screw on metal lid that is big enough to accept the size of brush you use.. Drill/ cut a hole in the lid to take the brush handle and push the brush through from the inside and adjust the height of brush in the jar so the bristles are clear of the jar bottom when lid is screwed on. Epoxy the handle in this position. Pour in enough thinners to cover bristles and screw on the lid. This avoids the loss of dope each time you wash out the brush. The jar contents become dope itself and can be used as is or transferred to other jars. It does work for coloured dope as well but to save having a lot of different jars I suggest you do this only while the coloured job is in progress and clean out the pigment when finished Spray can nozzles can be kept ready for use by popping them in a small jar and covering them with the relevant thinners or just use cellulose anyway.Saves a lot of frustration
Thanks: Klipkopwildlife, Flytilbroke, boz, Skydanz
10 Dec 2015 02:59 #20 by Skydanz
Replied by Skydanz on topic Covering Hints and Tips
I thought I'd throw my hat into the ring here as well. I wrote a nifty article on covering tips for our club forum. Check it out here:
www.sccmas.org/smf/index.php?topic=284.msg557#msg557
The sky is not the limit... the ground is!
Thanks: Eric, THE BLACKBIRD, Ex-Member, boz
10 Dec 2015 23:23 #21 by one tenor
I has loads of these as first wife was a hairdresser.They suddenly disappeared .Suspect wife #2 ditched them thinking I had them as a memento.Never admitted to it though . Must buy some more . However various sizes of " bulldog " clips are very handy but can crush some softer materials
11 Dec 2015 09:12 #22 by boz
Replied by boz on topic Hints and Tips
Very informative, thanks boz
11 Dec 2015 12:31 #23 by Eric
Replied by Eric on topic Hints and Tips
Use small 'crocodlie' clips, with bits of scrap wood stuck to the teeth, so they don't mark your construction.
Or, if you can find a source (scrap-yard!) use those little G clamps used for fastening add-on mudflaps to car wheel arches.
11 Dec 2015 15:29 - 11 Dec 2015 15:30 #24 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic Covering Hints and Tips
That's a very well made plug you have there Don what is it constructed of
Tony
Last edit: 11 Dec 2015 15:30 by THE BLACKBIRD.
Thanks: Skydanz
13 Dec 2015 15:08 #25 by Skydanz
I generally make the plug just as if it were going on the actual aircraft. It was made from rings of balsa and then sanded smooth with fillers and then fiberglassed with cloth and epoxy resin. Then I layout any panel lines or parting lines with 1/16" graphics tape and rivets with dots of glue, and then apply primer. Once I've sanded everything with wet-or-dry #600, I carefully remove the graphics tape which leaves a very thin groove in the primer.Polish and buff the plug with parting paste several times and then it's ready for molding.
13 Dec 2015 17:20 #26 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic Hints and Tips
I have been using blue foam to do mine, the problem I have with the foam is my fingers, making small dents, gouges :unsure: :(
I think they call the disease HAM FISTED :S
Thanks: Skydanz
15 Dec 2015 13:24 #27 by Skydanz
Replied by Skydanz on topic Scale Rib Stitching
I occasionally like to build scale models. Several items that really enhance the scale look is rivets and rib stitching. I won't go into riveting right now but I have a couple videos that show a pretty easy way to make a lot of rib stitching in a short period of time.
Scale Rib Stitching Part 1
Scale Rib Stitching Part 2
Thanks: THE BLACKBIRD, Ex-Member
15 Dec 2015 15:43 #28 by Ex-Member
rivets arghhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh.
one blob at a time. eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeep.
15 Dec 2015 15:59 #29 by one tenor
Tony B wrote: rivets arghhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh.
No Tony not Skydanz's way . One strip at a time . Knots and tapes too . I've seen his stuff . Very handy
25 Jun 2016 08:14 #30 by Ex-Member
From time-to-time SAM Speaks, the SAM 35 house magazine, comes up with a real gem and their June edition is no exception. In The Rubber Column, Andrew Longhurst has published a formula for calculating the maximum turns one can apply to a rubber motor. He stresses that the formula gives the maximum turns and for safety and sports flying, it may be worth cutting them back by 10%.
Max turns = 44 x sq root (motor length in inches cubed divided by weight in grams).
so a 30 gm motor 29 inches long would have max turns of:
44 x root(29 x 29 x 29 /30) = 1254 (rounding down to the nearest whole number)
This motor would be arranged in, say, 12 strands of 1/8", but that's not relevant to the formula. if you use it, do let me know how you get on!
Time to create page: 0.287 seconds
