- Thank you received: 1203
- Forum
- Forum Categories
- Construction Techniques & Aeromodelling Materials.
- Smokeless Smoke Generator .
- crash happy
The principle is quite simple (KISS). Take a container, stick a tube from the bottom into the airflow, fill with talcum powder & let gravity do the rest
- Ralpharr2001
- Thank you received: 1476
I could fit that on the Lanc so when the engines start up, they are sequenced on the transmitter, you get the exhaust smoke before it runs!!
- Thank you received: 14305
It is obviously a park-fly receiver, with only one stubby antenna, and you have put a large radio-wave blocking substance right next to it! (and probably a big battery right in front of it!)
Talc is a form of rock, and rocks do not pass radio waves!
en.wikipedia.org/wiki/Talc
- crash happy
- crash happy
I've not seen that arrangement before - all mine have both at the same end!
- crash happy
- Ralpharr2001
Only a small amount would be required for start up. a small pot inside each nacelle feeding each exhaust stack. Remember the battery for each motor is inside the nacelle so I have to take the top off to install the battery. I could 3D print a pot that sat up in the nacelle cover. Fill them up each time I went flying.
Not that i've given this much thought..........
- Ralpharr2001
However, even better on the Dambusters Lanc they had an exhaust shroud covering the stacks. By putting the outlet tube in the end where there is low pressure should suck the talc out into the air stream. You can see the shroud in the picture.
- Ralpharr2001
- Thank you received: 10722
Sounded awful
So quiet
- Forum
- Forum Categories
