- Forum
- Forum Categories
- Construction Techniques & Aeromodelling Materials.
- Smokeless Smoke Generator .
- crash happy
- Thank you received: 1203
- Phil Wood
- Inactivated User
Unless I'm seeing things, you have now got both your antennas parallel, not at 90' to each other!
Thinking of the talc 'packing' and not flowing, maybe scavenge an old cell-phone, (other sources are available, but we won't discuss that n here!), get the vibrating motor out, and strap that to the tank, so when you power it, the tank gets 'buzzed' to loosen the talc.
- crash happy
Eric wrote: -
Adding a gadget to 'vibrate' the powder to loosen it just might have the opposite effect, my guess is that it will cause the powder to settle rather than keep it loose.
- crash happy
The antennas are still at 90 degrees, you can't see the short one at the front on the photo, which is now vertical up the side of the fuz. The long one has just swapped sides & goes horizontally towards the tail.
Neat Idea with the buzzer. I will try that on a future development. ( see reply to Pol )
- crash happy
- crash happy
Use two tubes cut at say 45 degrees, both coming out the bottom of the fuz, one facing forward the other aft. Connect both to opposite sides at the BOTTOM of the container. Not only should it create some circulation but it alleviates the air hole at the top.
Thoughts ?
crash happy wrote: I think my flying will probably shake it around enough to keep it loose Mr Old Fart !
That's going to take a lot of BIG shakes.
- crash happy
With regards to " big shakes" a typical conversation between my flying buddy Stefan & I would be something like;
" Did you just say landing? You do know you're inverted don't you!"
" Really? must need trimming coz it's definitely flying better that way up"
Get the picture?
- Forum
- Forum Categories
