Multiplex Fun Cub
I believe the Fun Cub fuselage is 'Elapor'.
I fear you may find that whilst Poly C will bind with the glass fibre well enough it will tend pull away from the foam rather more easily.
Obviously a good 'mechanical' grip will help (don't sand the cowling too smooth!) and use plenty of Poly C on the first glass coat.
It doesn't work, Elapor is very slightly oily, and the poly tends to orange-peel, or blob, and runs away from the surface.
Eventually, after persisting, I got it to cover, but even then, it doesn't take much to make it peel off, once dry. It flakes off like dead skin sloughing.
The Humbrol fluorescent orange acrylic paint does the same thing.
The Dimona is the same stuff, with the same problem!
- Thank you received: 10722
Ready to maiden
hobbyking.com/en_us/rubber-foam-version-...with-silver-hub.html
www.google.co.uk/search?q=Suitable+paint...ceid=chrome&ie=UTF-8
Also this www.rcgroups.com/forums/showthread.php?1...Cub-%28Elapor-EPP%29 American admittedly but it may help.
Stephen, the new style motor mount is a thick aluminium plate where the original was plastic.The Beard wrote: Whats the advantage of the motor mount klippy it looks similar .I felt with my Fun cub was over time the fuselage lost rigidity and the mount vibrated through the fuselage.I even tried a wooden kit you could buy to help strengthen the motor mount but that didn't last long either
The maiden happened this morning, it was a great success. I was surprised at how slowly she flies, obviously the old one must have got very heavy over time. This new one is badly affected by any kind of turbulence and I have to reduce the amount of down thrust. I dialled in the recommended amount but I don't like the amount of 'drop' when you whack the throttle open!
Pic in post #186, the plate is just pushed in place for the photograph. There are 2 bearers glued into the inside of the fuselage that run back to the cockpit. If you study the plate you can see where 2 securing screws (1 each side) hold the plate to the bearers. The grub screws push on the bearers and allow you to adjust side and down thrust.one tenor wrote: What's securing the plate Tony? It looks as though it's just pushed into place?
On the original Cubs the plate was plastic and would deform quite easily.
On this one knowing that this might be the case I cut out the back of the battery bay before I glued the fuselage halves together, sure enough I had to push the battery back into the cut recess in order to get the required CoG.
And as I put in an earlier post on this thing, on one occasion, the battery escaped the clutches of the velcro strap, and ended up rattling around loose inside the the large hole at the front of the fuz, while I was aerobatting the model, and it didn't seem to make a blind bit of difference to the handling!
I can't recall if I put, when I first described it - that the wing servos had the plugs pre-fitted, so when the wing was pushed into place, the socket auto-connected. I discovered while flying it yesterday, that the left plug wasn't fully connected, so under flight loads, it was unplugging. I only noticed when I pulled flaps in a tight loop, just for fun - to see what would happen! - and the resulting gyration with one flap up and one fully down was - shall we say - interesting!
Needless to say, a small mod will be performed, and a pair of Y leads installed!
