- Thank you received: 690
Vintage Model Co Se5a
Alternatively, you are 'allowed' to spray paint markings in Kit Scale - see the Rules and Judges guide. In the limit, you can even spray paint the whole model if you want to, but in that case you would be penalised by, I think, 5 marks (see page 90 in the Scale Rules).
Rubber? I would put in one loop slightly longer than the distance between the hooks. That'll give you enough for some trimming flights outside to get the C of G, down/sidethrust and warps right for stable flight, preferably in a left turn. If you use longer rubber, it'll take you too long to wind it between test flights, any shorter and you won't be able to get it into the bus far enough to hook it round the rear peg. We can sort out the correct size and length of rubber for the competition on Sunday morning - I'll have several sizes with me and a rubber stripper if we need an intermediate size. I'll also have lube, stooge and a winder. Quantity of rubber will not be a problem, either.
You'll get four chances to fly in front of the judges over the day, only the best score will be counted, so we'll be able to do some trimming early morning (0800 - 0900) and over lunch, which should be enough to finally sort the model.
- Septic
I will do as you suggest and try with a shortish motor length, and get it to glide reasonably flat, preferably with a slight left turn.
Just got the struts to stain and assemble the beasty now
tap - tap.......rivet
Rubberwise I suggest a single slack loop of the 1/4" rubber. Well lubed and prestretched. Stretch wound . Take another loop of it and wind till destruction having counted the turns . Then use about 75% turns in the model . A blast tube would be handy too but the best guy to have asked is Andy as it is over 40 yrs since I handled rubber . Regarding the roundels to unstick them use a water /Meths mix applied round the edges using Q tips to tease them off. Then clean off any remaining glue.. Now look at the roundels themselves .Are they on a paper backing ? If so they will be waterslide transfers. You float hem in a shallow dish of lukewarm water. Lay them in the water one at a time and allow them to soak for a minute or two trying them from time to time to see if they will slide from the backing..When they do lift them from the water and start them slipping and slide them onto where you want them. pat them into place with a soft cloth from the centre out. Decal sets can be bought from Model suppliers/The waterslide roundels and fin flashes are only very thin films and should wrap around fin edges etc. Again Andy is the real guy to ask for the gen on these. As I Said I think these are water slide . If not get some Good luck Dan
- Septic
I did manage to get the fin/rudder flash to "form" around the curved edges, using watered pva to soften the paper and then form it around the edges, worked quite well. Still not a patch on sprayed masks, which is my usual method.
Onwards and upwards as the say
- Septic
and if it actually flies okay then I will be really pleased....
and some good flights.
- Septic
- Septic
getting closer
Have to work away for a couple of days so that might be it for a little while
This means that we must get the model to fly, but having said that, so must everyone else with their respective machines.
- Septic
A little painting done...
Septic wrote: ....... I presume a barely detectable turn to the left under a glide?
Looking good Septic, but that's the least I'd expect form a modeller of your caliber...
Yes, a slight left turn on the glide is good. Then try to maintain it under power with slight right side thrust and you also may need some down thrust. You may need some wash-in on the left wing to stop it digging in. Steam in a warp if necessary, but don't put a celluloid tab on it.... they look awful!
You can use scrap balsa for the down and side thrust, which you can remove for static judging.
- Septic
Going to try and get the wings fitted tonight
- Septic
Wings are perfectly warp free but the mounting jigs let me down, wont know until I do the glides as to how true they are rigged.... Probably my fault....
doesn't look much like the Shuttleworth Se, but does look like the box colour photo, and that is what matters
26g but that does not include the rubber
Cheers
Danny
