- Thank you received: 573
KK Ajax
- Mike Rolls
Thanks for posting the plan, etc. In the accompanying article it does say that the rigging 'has attracted considerable investigation by the Shulmanites and offers possibilities provided flier is patient at the trimming stage'. I'll bet!! I still don't understand it. Yes, the tail wold be operating in the downwash from the wing - a fact of life which enabled us to get away with HLGs with 0-0 rigging and the CG at 100%, but even so ......
Oh - and when you look at the plan you see a small circular mark low on the fus at about 50% chord - that doesn't indicate the CG - it shows where the timer was located.
- Mike Rolls
There were two schools of thought - the experts, who used the excess lift during power on to create a fast spiral climb, with the looping and rolling tendencies balanced one against the other, and the dummies like me who used a more or less straight vertical climb with the wing's lift more or less out of the equation - the expert's way was more efficient, the dummies way was easier to trim out.
This one was taking me far too long to get moving, so I invested in a VMC laser-cut kit and I have to say, it was a good decision. The cutting is perfect and the wood selection excellent!
So, after a bit of light sanding on the parts to get rid of the burnt edges, the tailplane and fin were laid down:
...followed by cleaning the burnt edges off the ribs:
...then fuselage joining:
...and a start made on the wings:
- Crashrr
- Senior Member
- Thank you received: 284
I will watch your progress with added interest.
www.aeromodellers.co.uk/forum/free-fligh...t?limitstart=0#49441
It may be of help or use with your 20” Competitor build, Crasher. You'll find advice on building and assembling the model, covering it, making the wheels and carving the prop within the thread. The plan is on Outerzone, here:
outerzone.co.uk/plan_details.asp?ID=597
- Mike Rolls
The Ladybird was a 42" semi-scale - very attractive - for ED Bee or similar.
I found it it was a PIXIE in addition I found these links. last one first. www.brchobbies.co.uk/brc_en/customer/address/index/one tenor wrote: I added Honi Soit Qui Mal Y Pense to the tail of your thread Andy. A nice thread and a nice model. Did you trim it out in the end and did it fly well.Re the wood choice and reinforcement ,the wood in kits in those days tended to being somewhat denser than today I had no probs with crushing formers in the ones I built. Perhaps I was just lucky eh? Is yours still flying. One of mine went into a reservoir and the other was trampled into the mud by sheep.All I could salvage was the nose block and the freewheel .There was another KK cabin job I made It was a very pretty looking plane but I can't recall it's name. Would Ladybird be the name perhaps About 20" span and very semi- scale in appearance but flew quite well with times about the minute mark on average . More or less depending on weather conditions.
www.modelflying.co.uk/forums/postings.asp?th=40495&p=2
Pixie plan outerzone.co.uk/plan_details.asp?ID=1375 Also this one of two on Aerofred aerofred.com/details.php?image_id=99230&mode=search
The other is C/L .As pretty as I recall her.
- Mike Rolls
- Crashrr
- Senior Member
It glides almost as straight as an arrow, which is a surprise to me! However, it does have a climbing tendency - perhaps why the original specified a lifting tailplane? I'll fit a noseblock and prop on it soon and give it some juice...
I see you've chosen a flat plate tail for your model which, as it happens, is much more efficient than a lifting tailplane on a model of the configuration that you've built.
For the next glide tests, I suggest you either move the C of G forward, or, if it's already on or in front of the main spar, put a sliver of balsa under the leading edge of the tailplane. If the model then pitches up under power, add some down thrust to the nose block by inserting a sliver of balsa between it and the front former at the top.
