edf funfly
15 Nov 2012 05:16 #1 by Ex-Member
edf funfly was created by Ex-Member
I need some input for the design of this one as edf's are new territory for me.
regarding thrust tube lengths and intake sizes.
i am thinking of intakes in the wing leading edges and a single exhaust out of the rear of the fuselage.
15 Nov 2012 06:03 #2 by The Beard
Replied by The Beard on topic Re: edf funfly
Do you have a picture in mind as to what you want it to look like maybe a Meteor
15 Nov 2012 15:03 #3 by Ex-Member
Replied by Ex-Member on topic Re: edf funfly
something like this, but in more of the funfly style.
15 Nov 2012 15:07 #4 by old fart
Replied by old fart on topic Re: edf funfly
Tony B. AKA Blooper wrote: I need some input for the design of this one as edf's are new territory for me.
It needs to be about 70 or so inches wingspan and capable of handling a turbine. :silly:
15 Nov 2012 15:34 #5 by Ex-Member
supply the turbine and i will do a 96" wingspan funfly to take it. :P
15 Nov 2012 16:42 #6 by old fart
I have three and a half turbines but none of them will fly a plane that size. :unsure:
15 Nov 2012 16:51 #7 by Ex-Member
ok 70" funfly then. :P :P :P
16 Nov 2012 02:54 #8 by Eric
Replied by Eric on topic Re: edf funfly
Can't offer much, Tony, but you need to keep the inlet and tailpipe no smaller and no larger than the fan duct i/d. Keep the pipes as clean as possible, no protruberances, lumps or bumps.
Don't forget, you won't get much static thrust from a d/f, because the blades of the impeller are pretty well stalled. Once n the air, the thrust will come up, and the amps will go down, as the fan unloads.
16 Nov 2012 05:39 #9 by Quorneng
Replied by Quorneng on topic Re: edf funfly
My advice is keep it light.
A ducted fan is only about half as efficient as a prop so to get any sort of endurance you need to carry a bigger battery but for the same total weight.
The other issue, as Eric pointed out, is that a ducted fan's propulsive efficiency rises with speed but of course so does the airframe drag but by the square!
I think you might have to significantly alter the Funfly aerodynamically to get it to go fast enough for the fan to see any benefit.
16 Nov 2012 14:58 #10 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic Re: edf funfly
I have a Lander 68mm fan in my Lander F9 that i cannot get to fly, with a hand launch it just flops to the ground, so i built a dolly for itand gave it a possitive angle of attack and it still will not lift, this is on 3and 4S lipos, i know they fly and fly well but i cannot get this one to even get airborn :sick:
16 Nov 2012 23:05 #11 by Ex-Member
well i have cut the first former/wing brace for the edf.
thats a 75mm internal diameter edf in there.
the fuselage and wing will need a complete redesign to build this one.
17 Nov 2012 00:40 #12 by Garry Pollard
Replied by Garry Pollard on topic Re: edf funfly
Good luck on this one Tony. You are a brave man.
17 Nov 2012 16:19 #13 by The Beard
Tony you obviously enjoy challenging yourself,I hope this is successful.
  • kamco kid
  • kamco kid's Avatar
17 Nov 2012 21:12 #14 by kamco kid
Replied by kamco kid on topic Re: edf funfly
I know absolutely nothing about ducted fans so can't offer anything constructive to this thread, but will be watching with interest.
Rich
17 Nov 2012 22:55 #15 by Ex-Member
Right have have an update shall we.
Basic wing frame is built and i am playing with the edf fitting location.
this is the front of the mount incorporating the wing brace along the twin spars.
Second support/mount and the tail end of the exhaust.
the exhaust will be planked from behind the unit to just proud of the rear former.
the l/e will be cut away and this is where the intakes will be made.
two triangular intakes either side of the fuselage giving about 40 sqcm total intake area.
Time to create page: 0.226 seconds
