edf funfly
18 Nov 2012 00:35 #16 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic Re: edf funfly
I think maybe the fan is always farther back, on the edf's i have they are two thirds of the fuselarge back, but they are foamies
18 Nov 2012 00:57 #17 by Ex-Member
Replied by Ex-Member on topic Re: edf funfly
That is a good point, but i am trying to keep the weight down by having as much as pos either on or in front of the cofg.
I doubt it will work very well, but if you don't try you never know
18 Nov 2012 02:32 #18 by Ex-Member
planking the thrust tube.
once this bit is done i can make up the first part of the fuselage and glue it on, then we can look at the rest of the fuselage.
i should just have enough room for the 2 servos either side of the edf unit with the esc in the nose with the battery.
but it is all suck it and see development this one.
The MCB BLUE ARSED FLY might not even fly. :P
18 Nov 2012 04:10 #19 by The Beard
Replied by The Beard on topic Re: edf funfly
Amazing as usual
18 Nov 2012 04:50 #20 by Quorneng
Replied by Quorneng on topic Re: edf funfly
A nice looking build.
I may be wrong but that wing section looks a bit thick for what needs to be a fast flyer to get the best from the EDF.
18 Nov 2012 05:01 #21 by Ex-Member
i did debate that myself, but as the wing tends to be a floater i thought it would more likely end up a power assist more than an outright power plane.
but it is all experimental. :P
600watt motor in a 3lb plane might just work.
18 Nov 2012 12:36 #22 by Klipkopwildlife
Replied by Klipkopwildlife on topic Re: edf funfly
I calculate 44cm2 for that fan area. I would suggest more inlet area, if I may be so bold! The outlet looks fine.
18 Nov 2012 14:42 #23 by Ex-Member
hmmmmmmmmmmm i thought it would be tight.:unsure:
i can add another small inlet under the fuselage with a bit of fiddling.:)
18 Nov 2012 19:03 #24 by Klipkopwildlife
Klipkopwildlife wrote: I calculate 44cm2 for that fan area. I would suggest more inlet area, if I may be so bold! The outlet looks fine.
Where I'm coming from is, the fan has to draw air in, there will be a certain amount of compression performed by the EDF, which will tend to increase the airspeed at the thrust pipe, (this is good). However if the inlet is the same size, or smaller then this won't happen.:)
20 Nov 2012 01:10 - 20 Nov 2012 01:11 #25 by Ex-Member
fuselage sides.
sides going on.
intake openings in the fuselage sides.
another view of the fan area.
fuselage coming together.
underside of the fuselage showing the edf outlet.
I have enlarged the wing openings for the intake ducts to give 48sqcm overall area.
i can still add a cheat intake under the fuselage if needed.
the rear of the fuselage looks weak but is quite strong and with the smaller tail i have planned we should be able to keep the weight down to under 3lbs.
Last edit: 20 Nov 2012 01:11 by Ex-Member.
20 Nov 2012 02:41 #26 by Quorneng
Hmmmmm 3 lbs.
Do you know the quoted static thrust from your 75mm fan?
You will need a good 2lbs for even modest flying.
20 Nov 2012 03:04 - 20 Nov 2012 03:29 #27 by Ex-Member
600watt
50oz of thrust.
so weight saving is a priority.
mind you the mkI funfly weighs in at 2lb 10oz flight ready, so if i can save a little bit more we should be ok for gentle flight.
Last edit: 20 Nov 2012 03:29 by Ex-Member.
20 Nov 2012 19:14 #28 by The Beard
A very interesting project Tony.
  • Dean M
  • Dean M's Avatar
20 Nov 2012 21:04 #29 by Dean M
Replied by Dean M on topic Re: edf funfly
Looking good
It must be a good way of doing it, as it Tony Nijhuis has made a turbine trainer in a similar style
I nearly choked on my latte.
20 Nov 2012 22:42 #30 by Ex-Member
Well today has seen some more progress.
got the tailplane fin and rudder all built.
The air intakes have been made, just need lining next.
Upped the intake size to 60 sqcm now.
And started sheeting the d box on the main wing.
not sure about the u/c yet, looks like i might need trike u/c. so wing mounted main legs.
just adds to the weight though.
Time to create page: 0.507 seconds
