- Thank you received: 680
Grumpy Tigercat
- Si_B
Got the nose on and sanded as well. Starting to look like a model now. Not much else I can do on the fuselage, so time to start cutting out some wing ribs.
Simon
going to be a nice model when it is finished.
i take it that it is having i/c engines fitted.
- Si_B
- Thank you received: 10722
- Si_B
- Si_B
- Si_B
Need to crack on with the other one so I can get them joined and the rest of the sheeting and cap strips fitted.
Also need to think about the best way to mount the thin wing servo? Ribs are only 3/32 balsa so might put a bit of thin ply either side of the servo bay ribs. Can't decide wether to just put a couple of rails in or to make a plate to glue in which the servo can screw to. Never used these wing mounted servos before. They are really nice....just lots of different ways to mount. I only want the horn sticking out to keep everything flush.
Cheers,
Simon
- Si_B
Had 20 mins to myself so got this done.
Gets tricky trying to work around the other wing, but there is no way that joint will ever fail!
Simon
with the servos, i would fix to a plate and then screw the plate to the wing.
Nice job Simon
- Si_B
