- Thank you received: 680
Grumpy Tigercat
- Si_B
It's a bit blurred but you get the idea. Starting to get a bit concerned about the engine angles, might have to do a bit of tweaking once she gets bolted together. By sorting the blocking first before fitting to the wing, I'm not 100% convinced about alignment as it is difficult to judge. As the motors are so close and being a small model, I doubt it will be super critical, but if I built it again I would change how the pods are fitted.
Simon
- Si_B
Think I will leave it till the weekend, get the wing fitted to the model (which I should have done in the first place) and the see if I can jig the fuselage level and see where things lie. Not sure I can be fussed to build another wing, so this may be the end of my Grumpy Tigercat.
Simon
please dont scrap it.
- Si_B
The other issue is the motor is 2 degrees off to the firewall so I must have a distorted plastic engine mount. Tried a few before I found one which fits the little 30 four strokes but the quality of the moulded mounts is not as good as I remember. Don't think I can start retro fitting different mounts so it looks like I will have to shim the motors once the wing is on to get everything pointing in the right direction. According to the plan there are no thrust angles built in, so hopefully not too much messing around.
Going to glue on the other pod to match the first and then block around the motor. Spinners may be a bit off eventually, but no worse than my Dual Ace.
Will post some pictures over the weekend if a I get any building time.
Simon
- Inactivated User
- Si_B
Been using those flat permagrit sanding blocks. Quite thin but strong enough to hold their shape. Not cheap but I've found them really good compared to my hand made sanding blocks. The rough one literally wipes the balsa away at a rate of knots.
Need to sort out how I'm going to mount the servo. Needs to be between the ribs as I'm not fitting removable covers. Can't decide between a couple of rails or a lite ply plate.
Simon
- Thank you received: 10722
Its looking good
- Si_B
Also decided how I'm going to mount the servos. Will post some images tomorrow.
Simon
- Si_B
- Si_B
Once that is back in, both the motors should be close enough so I can tweak the incorrect cowl and crack on.
Will post more pictures at the weekend if I get any time.
Simon
- Si_B
Would be a bit of a pain building back up with balsa as the cowl is now curved?
One good thing is it now points in the same direction as the other engine...........which can't be a bad thing. Still can't work out how I missed the engine being so far off but now it is sorted I can get on and finish the wing.
Simon
- Si_B
Got a bit more sanding to do, but it's time to get the wing mounted and the top deck finished off. Might even try to get hold of a bit of blue foam to carve a canopy out of as I'm not going with a clear one. All gets packed away tomorrow as I need to make my den back into a bedroom ready for a big family visit over Christmas.
Simon
- Si_B
But, the wing bolts are in and the wing is fitted. Need to build the top of the fairing to blend in and a canopy, then I can fuel proof everything, get the engines, tanks and servos in and cover the wing. Just can't seem to get the enthusiasm to finish this off.
Simon
Or you will have a shed full of unfinished models the same as the rest of us
