Antonov AN2
With easy access to each rib the process works well as the melted plastic actually 'reinforces' the hole, but on the first wing the servo is 13" and 7 ribs from the root so cutting access holes in the wing skin to 'melt' a hole in the rib is the favoured option at the moment.
With its simple construction and printed ribs I have seriously considered making a duplicate wing panel and simply doing it "right" as far as the servos are concerned, indeed I may still have to if cutting holes weakens the first one too much!
- Thank you received: 10722
A good idea but I am not sure I could keep a 13" long 3 mm drill on the correct line particularly as the very thin web on each rib does not drill at all well and the resultant 'ragged' hole would not accurately support the drill properly. The holes for flap servo which is only 2 ribs in from the root was 'drilled' reasonably well with a pointed needle file.
Feeding the aileron servo wire through the 'melted' holes in the ribs.
Seems to work well enough.
As long as the Depron repair 'inserts' are a really good fit UHU POR should restore virtually the full skin strength - I hope.
All six wing servos running from a single servo tester in 'auto' mode.
The six channel 35 meg 'synthesised' Rx I bought off ebay does not "synthesise" so it is stuck on what ever channel it was on!
Got my money back and the seller says I can keep it. Maybe just maybe it is simply a bad contact on its tiny,tiny push button.
Painted black so the camera can see it!
Really only a test to see if the process was practicable and it will be removed to allow painting.
The fuselage has a first coat of acrylic blue and the softer springs are in the UC.
The blue acrylic on the fuselage has added a bit of weight but the Depron was a bit 'rough' so when rubbed down between two coats has produced an acceptable finish.
The wings being white Depron only needed a 'dusting' to achieve a uniform finish.
The cowling will be red and white.
Rigging and the cockpit canopy next.
Basically a multi faceted hollow Depron box with Fablon glazing frame strips.
Would you believe I made the engine cowling no less than 15 mm too long!
It is surprising noticeable now the rest of the plane is more or less complete so it all has to be reprinted!
The new 'correct length' motor mount & cowl is on but not glued yet.
The replacement radio is in and it all works although the internal wiring needs to be tidied up a bit.
I fear the U/C is just a bit too far back as it topples forward a bit too easily.
Fortunately it is not that much of a chore to alter the geometry and reprint the undercarriage legs so the wheels are moved forward 10 mm.
The ASh-62 looks the part.
I think I might try and print a representation of the AN2's characteristic variable pitch hub assembly.
