V-2 with wings rebuild 2021
i certainly could do that but as a vertical riser that is already short of thrust there is no real option to reduce the total power even if it improves the energy efficiency.
My first objective is to get both motors to draw the same power at full throttle so it will adding the maximum energy to the air stream. The thrust at low throttle is not really an issue, it will be plenty! I have two Watt meters so I can measure the amps in real time.
What I think is happening at the moment is at full power the rear prop tends to draw in more air than the front supplies. This allows the front to speed up. Unfortunately the power of a brushless motor falls away quite rapidly outside a fairly narrow speed band.
Now whether the same front to back power distribution remains the same on 4s rather than 3s is any bodies guess.
The problem is further complicated as apart from their relative pitch there is also their relative diameters. I have somewhat arbitrarily selected an 85% area ratio for the rear prop. This figure as the area of a nozzle does create maximum thrust (but not by much) on a single fan. I have no idea how sensitive the area ratio might be in a tandem arrangement.
Axial air compressor theory indicates that guide vanes play an important part in pressure generation but in a twin fan it is not pressure we are after but airflow speed.
All I can say for certain at the moment is the two motor tandem fan is creating the same thrust on 3s as a one motor fan does on 4s. A result that is not really good enough!
Plan B is to use a replacement 70 mm EDF so the V-2 would behave as original.
Plan C is to use just one of the RS2205 drone motors with the largest ducted prop I can get into the available space.
According to the figures on the Emax web site the RS2205 with a 4x4.5 3 blade on 4s can produce 732 g (26 oz thrust) drawing 20 A. This might be enough given the considerable weight saving that would result from both the smaller motor and battery.
The issue is still the torque at what would be a relatively slow launch.
A bit of CAD work suggest I can print a suitable duct and include motor supports with appropriate counter torque curvature.
With a bit of experimentation I might be able to virtually eliminate the torque and if what I am told on other web sites is true it might actually increase the effective thrust at the same time. Yeah right!
Anyway it could look something like this with a 4 x 4.5 x 3 blade.
We shall see.
They are OPTO so they needs a separate BEC.
The wiring 'lash up' to test it all works on the Plan "A" 88 mm contra EDP.
Not tried it on a 4s yet.
One of the 2205 racing drone motors with a Plan "C" 4 blade 4x4 prop.
I tested this on on my thrust test rig. It generated 601 g (24 oz) thrust drawing 15.1 A on a not fully charged 4s, which is quite impressive. But after just a few seconds running it made a 'out of sync' squeal and stopped pretty quickly. After experimentation with a spare ESC and motor it proved to be the motor that had 'lost' a winding internally.
I have 4x4.5 3 blade on order which might actually generate a touch more thrust.
I am printing up the rest of the 4" (102 mm) EDP cowling.
Plan C will simply depend on how much weight is saved from the lighter components against the reduced thrust available.
I tested the contra EDF on a 4s
Loads of noise but not a huge amount of thrust - 430 g and drawing 15 A.
A bit disappointing as going up to from the contra's 3.25" and 3" to a single 4" prop achieves 600 g and using the same amps.
With a bit of development I may improve the Contra's thrust but it does look unlikely to reach 600 g let alone exceed it.
The completed 4" (102 mm) EDP.
It is of course quite a bit lighter, 63 g against 98 g for the 88mm Contra
It has a 'built in' 85% FSA nozzle.
So it looks like the V-2 with Wings will get the 102 mm EDP.
There will be other weight savings from the V-2's original form.
1000 mAh 4s in place of an 1800 mAh.
A much lighter ESC even with additional BEC.
With only 1/3 the amps lighter ESC to motor wires. Significant as they are 1000 mm long!
A lighter gyro rx in place of its separate rx and gyro.
The reduced EDP weight over the original 70 mm EDF may allow smaller servos to be used and for them to be placed directly in the fins thus removing the need for four 600 mm long snakes.
Some checking of the actual airframe weight, or rather what's left of it, to see if it is in right ball park and I might start cutting some Depron soon.
For prop thrust there is no substitute for diameter!
- crash happy
- Thank you received: 1203
The entry duct to the EDP was damaged when the 70 mm EDF disintegrated so it will need to be replaced.
It carries no load and is purely an aerodynamic fairing. The EDP is supported and the thrust transmitted to the fuselage entirely by the four Depron fins.
The fairing will be built as a half shell over the plan so the appropriate 1/2 formers have been printed.
I seem to remember it was not an easy shape to plank.
It did not just loose it blades but the fan and the driver. The shaft snapped and exactly at the beginning of the 'flat' in the shaft to locate the retaining grub screw.
Having examined the rear fuselage in detail it looks like I might be able to use the rear fuselage cone 'as is'.
A quick check shows the airframe (less the nose!) but including the heavy ESC, 4 'heavy' servos, 4 snakes and a separate gyro weighs 360 g. The 4" EDP is 61 g. The 100 mAh 4s is 110 g. That gives a total of 431 g.
If the EDP gets close to the 600g measured test thrust then it looks a possibility.
No it is steel, probably a nickel steel and pretty hard. I suspect it is also surface chromed.
The fracture is a classic grey colour showing the fine grain structure.
I was thinking of buying a new 70 mm 12 blade fan but the shaft is now too short .
Made a start on removing the 'heavy' components from the airframe.
This is always the hard bit as you have to destroy more than crash actually did before you can start repairing anything.
The control surfaces removed prior to removing the snakes.
One of the fins is badly 'bent' so may have to be replaced.
The first bit of real weight saving. The old 60A ESC & heat sink alongside the Little Bee 20A ESC & 3A BEC.
This saving alone is likely to be more than the weight of the complete rebuilt nose.
- crash happy
Don't blame me, I wasn't even in the country when it went down !
- Ralpharr2001
- Thank you received: 1476
I was not after hovering as such but more to make a scale rocket take off vertically and fly aerodynamically.
It does show that a single prop (6"?) can provide enough thrust and be controlled with vanes using a drone control unit.
I am bit surprised it did not have normal X & Y control which surely must have been available as it is in a racing drone.
With only a 70 mm EDF (2.75" dia) in my V-2 my vanes were too small to provide adequate control but did provide some vectored thrust assist in a tight aerobatic manoeuvre.
Still removing bits.
4 servo and their snakes, rx, gyro and redundant Depron support structures.
In total it weighs 63.6 g.
Of course some weight will go back in but likely no more than 25 g.
The first objective will be to get the printed 4" EDP installed into the rear of the airframe. It will the be possible to use the airframe to measure what the thrust actually is and to answer the question "Does it all hold together?"
