freeCAD and fuselage creation
22 Aug 2023 20:34 #196 by Eric
Replied by Eric on topic freeCAD and fuselage creation
As I've never used pla, I can't comment on that - BUT - Araldite is heavy and goes brittle, while I understand that pla is a bit flexible, so you might be introducing a shear line where the araldite stops.
23 Aug 2023 08:33 #197 by Klipkopwildlife
Replied by Klipkopwildlife on topic freeCAD and fuselage creation
I'd go with medium Cyano without kicker so it can run in a bit.
Thanks: jon.in.swansea
24 Aug 2023 00:03 #198 by Quorneng
Replied by Quorneng on topic freeCAD and fuselage creation
jon
Remember you have to use foam safe CA on foam.
I have found using foam safe CA is not as effective foam to PLA as ordinary CA is joinng LW-PLA.
I do agree with Eric that whilst Araldite is srong it is also brittle. ALW-PLA and foam structure will give quite a bit under load.
There could be a danger that an Araldite joint will simply break away from the foam..   .
Time to create page: 0.264 seconds
