- Thank you received: 10722
JB Atoms
My measurements go in half a brick lengths
While the piston/cylinder fit is still tight (very tight) on both engines the big end fit with the original crankshaft and conrod is very sloppy = badly worn.
This is the arrangement that holds the gudgeon (wrist) pin in.
I presume the gudgeon pin retainer is screwed into the piston?
I mean the induction hole in the shaftone tenor wrote: Can't make a lot of difference can it Klip? As screwed insert comes in from the other side / front
I meant to ask you would you replace the other Con Rod for me as well please? An ounce of prevention etcone tenor wrote: I agree about the conrod Klip Not enough meat round the crankpin and too thin in the shank. I would leave it blocky with just enough taper or relief to clear piston skirt The sloppy fit is likely down to the metal stretching in the big end eye I think. Next thing would have been fracture.
Thanks John O/T P.S. I thought of lapping the piston and cylinder by hand with drop of dilute metal polish. What do you think?
Yes, and on the complete engine I can't get it out to make a replacement conrod!Quorneng wrote: Klippy
The hole is now only half as long as it is on the complete engine, I would guess the crankcase volume is only 75% or less of what it was.one tenor wrote:
- Mike Rolls
- Thank you received: 573
