- Thank you received: 352
Westland Whirlwind #3
- chookman
- Premium Member
The plan details 1/8" balsa for most of the sizes, but aft of the C/G I got them to cut this down to the ribs to 1/16 and fuz formers to 3/32.... which they did, ...also they supplied the origonal sizes, at no extra cost......now that's service
Forward of the wing I will mould the nacelles cowling out of acrylic sheet, while waiting for the kit I built up dummy nacelles to mould over
- chookman
- Premium Member
- chookman
- Premium Member
- chookman
- Premium Member
The whirlwind is one of those marmite aircraft to me.
but i t looks to be a lovely project.
- chookman
- Premium Member
all of this done before the other side planking is laid on
www.aeromodellers.co.uk/forum/free-fligh...build?start=45#65609
The Whirlwind has always been a favourite of mine ever since I was given a 1/72 Airfix model of it as a kid. It's a great shame it never went into service with a couple of Merlins on the wings! It's even a bigger shame that there isn't one left...and don't talk to me about the Hornet, either.
On the other hand, full marks to the Whirlwind Fighter Project - a team of enthusiasts who are trying to get a replica together for static display;
www.whirlwindfighterproject.org/
- chookman
- Premium Member
deg
- chookman
- Premium Member
- chookman
- Premium Member
I've had a computer hick up, .....all good now I think
With that part put aside, the nacelles was the next bits to tackle. because I wanted the rear of the nacelle to be attached to the flaps, I had to work out how to hinge them, rotating down and out, if the full size flaps had a verticle line it would be easy ...,but the line angles forward from the bottom up, that rotation increases the length of the nacelle at that line, there was no info on the web, so I had to invent something that would do it.... ummm I tried a few options and came up with this
- chookman
- Premium Member
- chookman
- Premium Member
Today I've fitted in the flap servo inside the nacelle ( 10kg standard one ) forward of the C/G, driving the nacelle rear out.
Pics later
- chookman
- Premium Member
I've never built a wing upside before, in all of the 50 odd yrs, but it is progressing, lots of ribs to fit, centre section so far, according to the plan the top of the wing is flat, and the bottom tapers up to it, W1 is about 28mm thick and W23 is 12mm. so there is quite a taper
- chookman
- Premium Member
Now the next thing is to glue that large flap onto the 2 nacelle rears
Cheers
Barry
It also had a built in telescopic ladder that dropped down on the port side!
I knew it had leading edge intakes for the radiators but had not realised they were actually mounted behind the spar so the air actually passed right through the wing (and spar!) and exhausted via a movable section above the flap as seen is this picture.
When I first saw this I originally thought it was some sort of platform for aircraft maintenance.
