hawker sea hawk
10 Jan 2016 20:47 #61 by one tenor
Replied by one tenor on topic hawker sea hawk
Really great job
18 Feb 2016 17:01 #62 by Ex-Member
Replied by Ex-Member on topic hawker sea hawk
well i bit the bullet today and soldered up the esc and motor wires.
wiring all done now and edf tested.
need to measure the thrust, but it does move along the floor under full thrust now ( even if it i noisy)
i have just enough 3mm depron left to finish covering the underside of the fuselage.
so thats the job for this weekend (after camper engine swap)
then cover paint and connect up the servos.
18 Feb 2016 17:04 #63 by Quorneng
Replied by Quorneng on topic hawker sea hawk
Does that ESC get any form of cooling?
18 Feb 2016 17:13 #64 by Ex-Member
there will be a duct feeding cool air to the esc when i design it.
and it will be positioned so that the heat sink is in the air flow.
21 Feb 2016 17:00 #65 by Ex-Member
stuck the blue foam nose cone on and flared it in.
playing with the canopy now.
two bits of depron to do under thee fuselage and i can finish this one off.
21 Feb 2016 20:10 #66 by one tenor
Brilliant Tony
22 Feb 2016 18:07 #67 by Ex-Member
as it was raining this morning i managed to do some more painting to the sea hawk.
will finish the sheeting and covering i hope tomorrow.
23 Feb 2016 12:46 #68 by Ex-Member
spent an hour before the camper finishing the sheeting on the underside.
need to cut and make the esc cooling duct next and then i can cover and finish the painting.
the canopy needs sorting as well, but we are nearly there. :)
24 Feb 2016 19:42 #69 by Ex-Member
finished all the sheeting now, sanded the joins and edges.
ready to cover tomorrow if i get time and my back allows.
a little bit left to do with the canopy fixing, then i have to fit all the controls and that's it finished.
will get back to the Lightning then and try to find some money for parts for the meteor. :)
25 Feb 2016 17:52 #70 by Ex-Member
finished covering thee fuselage, can finish off the painting tomorrow........ i hope.
26 Feb 2016 00:16 #71 by one tenor
Are the insignia etc hand painted /Tony or decals . If painted you are an artist sir
26 Feb 2016 17:59 #72 by Ex-Member
well today i finished covering the underside.
then i slopped some white paint over it.
then i added some rough panel lines.
looks ok from 50ft away, so that's good enough for me.
so now i have to do the markings, panel lines on the top and then hinge and connect the control surfaces.
nearly done at last.
can get back to the lightning soon.
27 Feb 2016 17:41 #73 by Ex-Member
well i spent the day adding markings with a shaky hand,don't look that bad if you squint from a distance. :P
well all that is left to do is to connect everything up, give it a coat or two of sealer and a canopy magnet.
job done. ;)
be the dreaded flight test soon. :unsure: :unsure:
27 Feb 2016 17:46 #74 by Garry Pollard
Replied by Garry Pollard on topic hawker sea hawk
What are you on about !!!!!!! Superb job and a superb thread Tony, congrats. If the maiden is half as good as the model , it will be fine. Very impressed
27 Feb 2016 17:58 #75 by Ex-Member
well IF i ever fly it. :P
hmmmmmmmmmmmmmmmmmmmmm.
Time to create page: 0.218 seconds
