- Thank you received: 1980
- Forum
- Forum Categories
- General Chat (Including Our Fun Thread, The Cafe)
- The Café (There is no Topic)
- Flytilbroke
PS, BBQ in Scotland in case some one jumps to conclusions
- Thank you received: 10741
- Thank you received: 14334
In view of all the work thats been done on the fuselage and cowl and the rehinging of the elevators to be more like the real one i have to repaint them all, the wing need touching up in places and the centre section needs repainting
I was wondering if SIR would like another colour on the fuselage and cowl as i remember ten years ago when i built it you remarking about there should be bright colours on it
I painted it in the colours of the 1936 model that flew in that years Olympic games in Germany
I've come across a novel but unusual boost switcher. The Pololu range. TheU1V10F5 takes an input from 0.5V (actually I tested it to a tiny bit lower) up to 5V and it gives a 5V output. But this is where things go differently. If you increase the input voltage above what it is supposed to deliver, the device drops into a linear regulator mode keeping Vout at 5V. MAximum input current (in switcher mode) is 1.2A so Iout is whatever it needs to be to achieve that. Efficiency approaches 90% for Vin at 3V So ideal for generating a supply from a single NiMh or dry cell. Also useful for Li-ion except that in that case you'd have to check for minimum discharge voltage as this would carry on until the point the cell is damaged by too low a terminal V. They make other voltage ones too, 3.3v and adjustable. But the thing about this that's a bit weird. They only seem to be available as modules, eg. from the Pi-Hut where I got mine.
I've searched for the data sheet and they only ever show the ready built module, about10mm square, never details or specs on the raw device.
But as he only deals with problems in his spare time, don't expect a quick result.
www.bbc.co.uk/news/articles/c203v72wwp7o
airlive.net/incident/2025/10/09/investig...ChdA#google_vignette
- Forum
- Forum Categories
