- Thank you received: 1047
A go at a Foamie
- Magpie
forums.modelflying.co.uk/index.php?/topi...ons/page/2/#comments
The internal motor winding has been pulled out & twisted beyond use.
Note I have removed the circlip on the end of the shaft to see If I could dismantle the motor but the bearing must be pressed in.
- Magpie
This is the back view of one of the 7.5 x 4 props straight out of the packet. The blade pivots are a reasonably close fit in the plastic housing.
This is a back view of the 6 x 4 prop in use when the motor failed, there is a gap at the side of the blade pivot
This is the prop dismantled. Note that the pivot screws are bent.
It looks to me that the cause of the vibration was too much side play on the blades.
I assume the bent pivot screw was the result of the vibration.
I had bought two 6 x 4 and two 7.5 x 4, that being what was available.
Both the 7.5's are a reasonable fit, the other 6 x 4 also has alot of side play. It suggests that the 6 x 4's were from the same batch, possibly assembled by the same person,
The pivots on the 6" blades are 4.9mm thick, those on the 7.5" blades are 5.9mm.
Should different plastic housings have been used on the different sized blades?
They were all got from Aliexpress. I'll try complaining but I'm not optimistic.
It also looks - to me - that the blades are the wrong ones for that unit, as the blades appear to be too fat to fold flat without catching the back-plate. The blade hubs are too short!
- Thank you received: 10722
- Magpie
The top one is the one that had been on the motor when it failed, I have put some washers in as spacers (more on that later). The next one is the other 6" prop & the other two are the 7.5".
- Magpie
I didn't get the roaring vibration but I did not push it too far.
I then tried the other 6" prop without any washers.
I couldn't hear any difference between the two but my hearing is not of the best.
I have ordered a sound level meter. I will have to drive the ESC from my Raspberry Pi so I know I'm running the two props at the same speed.
I am now wondering whether the LE2204 motor is acting like a tuning fork (or the Tay Bridge).
I would suggest that any noticeable vibration at 1/4 throttle means stop and cure the balance.
Out of balance forces increase by the square of the RPM. 1/4 to full throttle means at least 16 times the forces.
A really rigid test mount doesn't help.
Note on the full power run of the rotary although the test stand was loaded down with a big lead weight it was also sitting on a 5mm thick foam pad to allow it to move about a bit to absorb any vibration.
www.youtube.com/shorts/kOjTkcVH5x8
- Magpie
They could only bend if there was a gap (which there is) between the blade & the side walls.
The vibration started at just over 50% ish.
The motors are mounted on the 2x1 arm using screws through it into T-nuts.
Maybe if I mounted a piece of ply on short stand-offs on top of the arm & fastened the motor to that it would reduce the resonance.
The whole thing stands on a car floor mat to help quieten it.
75% would be about 13k rpm
Just out of curiosity, put the clamping bolt back in, and fit the backplate to the motor, without blades, bolts, or spinner, and give that a run, to see if that gives the motor the 'shakes'
- Magpie
Can you see the missing piece on the slots on the scanned image?
Remember the motor is a write-off. I've got to wait for a replacement before I can do much more.
- Magpie
The replacement motors should arrive this week so that means some very carefull testing on my rig. I've bought a cheap sound level meter, I can't think of any other way to monitor the vibration.
Or use shorter pre-made wires!
- Magpie
I'll do as you suggest but put in a thin vertical barrier which will reach right up to the wing lower surface.
My replacement motors should come in the next day or two then I can see whereabouts under the canopy the battery has to go to get the CG in the right place. That will determine where the receiver can go (under the wing or under the canopy) & hence what space there is for the wiring.
Soldering 32 AWG servo wire is also a bit of a fiddly chore but it is worth the effort so every lead including the motor and ESC has just a single plug on it and is exactly the right length.
Even better if you can get the servos out the way as well
Loads of room!
