- Thank you received: 1047
1200mm Dragonfly
- Magpie
outerzone.co.uk/plan_details.asp?ID=15454
I've scaled up the OZ drawing to give the 1200mm span & am doing the fuselage sides in the conventional manner in balsa on the plan but have printed out some spacers to make it more likely the 3D printed formers will fit.
I'll be sheeting the nose in 1.6mm balsa but intend to cover the rest with laminating film.
Has anybody tried this?
- Thank you received: 10580
- Magpie
After spending a whole day trying to do the windscreen I discovered the Lofting utility which apart from sometimes giving weird shapes generated a thin (2mm) shape which fits a treat. It needed alot of support on the printer which was fiddly to clean off.
The stringers on the nose give it alot of strength but I still intend to sheet it.
- Thank you received: 14148
- Magpie
- Magpie
- Magpie
The front former/dihedral brace isn't sitting level.
This is the calculations to size the V-tail from the conventional tail & fin.
theampeer.org/ampeer/ampapr23/v-tail-design.pdf
In my own design example despite its quite steeply inclined V tail it did not work well until I added quite substantial vertical fin "plates" at each end.
Only when they were fitted did the nasty nose drop "yaw" with any sort of bank become readily manageable.
or
for a totally new drawing, guess what a flat tail area looked right, then mark that, and do the angled stick thing again.
The aim is to get about 1/3 more area per side than the flat tail would have.
It sometimes looked a bit too big, but I didn't have any 'fishtail' models.
- jon.in.swansea
- Thank you received: 1147
- Janine
- Senior Member
- Janine
- Thank you received: 121
You have to excuse us as most on this forum have been doing model planes for a very long time and in many cases not only planes! Some of us have even done some full size as well.
So the "how" we learned is just by "being around" with quite a bit of "trial and error" along the way. Obviously following a web site like this and asking questions helps too. A benefit we did not have pre internet!
Don't get me started on sewing machines!
I bought a vintage "folding" 15K Singer treadle machine at a car boot. Restored it to working condition. 35 years on it now sits, still in full working order, as our hall table. It also amazed quite a few kids (mostly lads!) at my son's junior school "open day" by allowing them to have a go at sewing up a little pouch.
It did not end there as I now have a collection of 13 vintage sewing machines!
One of them is even my mother's hand crank Singer that was a wedding gift. An important item for a young couple starting out in 1931. How times have changed.
- Magpie
