- Thank you received: 1484
Fairey Gannet AEW3
- Ralpharr2001
- boz
- Thank you received: 1420
you all know i dont fly or build, but anyone looking in will be very impressed by the work that goes into a model aircraft.
- Ralpharr2001
- Ralpharr2001
- jeffwill6
- New Member
- Thank you received: 31
- Fly-Navy
- Thank you received: 295
- Ralpharr2001
The arm from the servo has a cranked end. By changing the angle of the crank changes the 'throw' of the surface as does changing the amount the servo rotates.
The box the crank sits in is made from ply or similar but the surface the crank rubs on is from various materials such as fiberglass, paxolin, formica or anything that is hard. The secret is to get the open area of the box the crank sits in as tight as possible to the crank thickness without jamming the crank.
- Ralpharr2001
- Ralpharr2001
'Next time' !!!!! Not sure there will be a next time. This is a mammoth project for me so in future I will stick to plans where all the issues have been ironed out! I will not modify the plans, I will build them as designed.......... :sick: :sick:
Must finish the Firefly, that's the next big build. [badass]
- Ralpharr2001
Also sheeted the top of the starboard wing. The magazine in the photo gives some idea of the wing area.
