  • Ralpharr2001
01 Aug 2017 13:24 - 01 Aug 2017 13:29 #1 by Ralpharr2001
Fairey Firefly MK5 from Vance Mosher plan was created by Ralpharr2001
Started my next project an 81" wingspan Fairey Firefly by Vance Mosher of Vanguard Plans ( www.vanvan.us ). Yes I know the Gannet is still under construction, as is the Curare!! :dry: But one cannot have too many projects on the go!! :P Besides the Firefly has been fully designed and I don't need to design or change anything so it should be quite straight forward. :lol: :lol:
My father was HMAS Sydney during the Korean war and worked on the Firefly. Hence my interest in this subject. I did start this model a number of years ago but had two house moves since then and what I had built has got damaged/lost/deformed. So i'm going to start afresh. It is an 81" wingspan model. I am going to install electric power rather than an oil burner.
Sadly Vance has passed away so the the plans, laser kits and parts have been taken over by Chuck Greaves. Chuck was very helpful getting my order sorted and shipped. I sent away for the plans, build instructions and the laser cut parts which arrived from the USA 2 weeks from order.The plans are on 4 sheets, very informative and detailed. Laser cut pack is very good with just a few laser burn marks. Nothing a wipe over with sandpaper won't sort.
Assembled to bottom of the fuselage over the weekend. The design is a centre (1/4" sq balsa) crutch onto which the lower and upper formers are added. Then the fuselage sheeted with 1/16" balsa.
Retracts are on order. Vance has a specially designed set of air operated retracts but I prefer electric servoless type so have sourced them elswhere. I've yet to sort motor and servos.
Last edit: 01 Aug 2017 13:29 by Ralpharr2001.
Thanks: Klipkopwildlife, Quorneng, blue123, Fly-Navy, one tenor, boz, Firewood, Nigel and 1 other people also said thanks.
01 Aug 2017 14:06 #2 by Mike Rolls
Replied by Mike Rolls on topic Fairey Firefly MK5 from Vance Mosher plan
Looks good!
Thanks: Ralpharr2001
01 Aug 2017 15:50 #3 by Ex-Member
Replied by Ex-Member on topic Fairey Firefly MK5 from Vance Mosher plan
Lovely aircraft.
should be a beauty when she is finished.
look forward to following your build thread.
01 Aug 2017 19:34 #4 by Fly-Navy
Replied by Fly-Navy on topic Fairey Firefly MK5 from Vance Mosher plan
Now your talking Ralph, been waiting a long time for this one to arrive in one of your builds. Beautiful looking a/c and not modelled enough in my opinion. Eagerly awaiting further posts, are you sure we cannot tempt you to install a noisy smelly thing?????????
01 Aug 2017 21:24 #5 by Squirrelnet
Replied by Squirrelnet on topic Fairey Firefly MK5 from Vance Mosher plan
As the others have said nice interesting prototype that looks like it will make a great model, I can see your attraction to it.
Looking forward to seeing this one develop
  • Ralpharr2001
01 Aug 2017 21:33 #6 by Ralpharr2001
Replied by Ralpharr2001 on topic Fairey Firefly MK5 from Vance Mosher plan
Fly-Navy wrote: Now your talking Ralph, been waiting a long time for this one to arrive in one of your builds. Beautiful looking a/c and not modelled enough in my opinion. Eagerly awaiting further posts, are you sure we cannot tempt you to install a noisy smelly thing?????????
Definitely not!! :P But it will have a sound system on board to make the right Griffon noises.
Thanks: Fly-Navy
01 Aug 2017 22:50 - 01 Aug 2017 22:53 #7 by Fly-Navy
Will let you off then, tried to put engine run up youtube in post but no joy.
Well I was a fly boy matelot, my excuse anyway :silly:
Last edit: 01 Aug 2017 22:53 by Fly-Navy.
02 Aug 2017 04:00 #8 by boz
Looking forward to this build, along with your others, boz. :)
02 Aug 2017 04:21 #9 by one tenor
Replied by one tenor on topic Fairey Firefly MK5 from Vance Mosher plan
Likewise for me too John
  • Ralpharr2001
04 Aug 2017 21:04 - 04 Aug 2017 21:05 #10 by Ralpharr2001
oooooh!! Look what the postman delivered today while I was at work. :woohoo: :woohoo:
These servoless retracts are rated for 8 - 10kg models so just the ticket as the model is going to be approx 16lb. The action is very smooth. The oleo's were separate to the retract units and slightly longer than required. So I put them in the lathe tonight to get the pivot to axle length correct. Took 20 minutes but they are spot on to the plan. They will need a bit of dressing up to get the scale look but a great starting point. If ever there was an incentive to build a wing these are it.
Not working tomorrow so I can crack on with the build. My sheet balsa order has arrived from Balsa Cabin so I have everything I need to complete the air frame. Only a few things left to buy, motor and ESC and I'm not decided whether to go Hacker or something else. The sound system has been sourced and I will get that at the end of the month.
Last edit: 04 Aug 2017 21:05 by Ralpharr2001.
Thanks: Ex-Member, Quorneng, blue123, boz, Squirrelnet
04 Aug 2017 21:10 #11 by Ex-Member
They look nice young man.
now where are the build pictures. :P :P
04 Aug 2017 21:32 #12 by Squirrelnet
They look like very nicely made retracts Ralph, can't wait to see more ;-)
05 Aug 2017 07:08 #13 by boz
Very nice teaser, (you naughty boy), post 1 picture then leave us wanting more. ;) :whistle: :woohoo:
  • Ralpharr2001
05 Aug 2017 17:44 #14 by Ralpharr2001
Here's another teaser, and build photo's for Tony. :P
Got on well today. The bottom section of the fuse is pretty well built, just sheeting to do. As you can see the laser cut parts go together very well. Remember, the photos show the bottom half of the fuselage as first it is built upside down. When all the sheeting is done I will turn it over and build the top onto this bottom section.
As expected I have already deviated from the design!! :whistle: :whistle: I have built in the arrestor hook troughs that allow the arms of the hook to sit inside the fuselage. I have also modified the section where the hook sits to be more scale. Yes the hook will be operated by a servo.
This is a picture of the full size. You can see what i'm trying to replicate.
Thanks: Ex-Member, Quorneng, blue123, boz, Firewood, Squirrelnet
  • Ralpharr2001
08 Aug 2017 19:56 #15 by Ralpharr2001
Had a break from balsa bashing and did a bit of brass bashing instead. Made the tail hook arms and hook.
First step was to make the arms by flattening each end, drilling holes for the pivot pins and cutting the hook. The whole assembly was then silver soldered together.
Then I added some thin brass sheet to form the inner and out flange which was soft soldered into place.
A little bit of shaping and we have a hook that is close the scale that i'm happy with. Compare it with the picture in the previous post of the real thing. I will add the internal bracing angles with a soldering iron later. With some filling, sanding and painting it will look quite good.
Thanks: Ex-Member, Flytilbroke, blue123, boz, Firewood, Squirrelnet, Crashrr
Time to create page: 0.664 seconds
