28 Oct 2017 13:45 #31 by Neddy
Replied by Neddy on topic Fairey Firefly MK5 from Vance Mosher plan
Gosh - all that technology and engineering :kiss: Not done silver soldering for years......... and how quickly you build. there is not a war on you know! The detail you are incorporating is showing signs of a pretty ace machine.
Thanks: Ralpharr2001
28 Oct 2017 16:33 #32 by Crashrr
Replied by Crashrr on topic Fairey Firefly MK5 from Vance Mosher plan
Big RC crates are not my thing, but I'm enjoying your attention top detail and metalwork. Excellent craftsmanship. I must alert my brother to this build, this is right up his strasse. (He lives in Germany!)
28 Oct 2017 18:12 #33 by Mike Rolls
Replied by Mike Rolls on topic Fairey Firefly MK5 from Vance Mosher plan
Looking very, very good - well done!
  • Ralpharr2001
29 Oct 2017 17:06 #34 by Ralpharr2001
Replied by Ralpharr2001 on topic Fairey Firefly MK5 from Vance Mosher plan
Spent a little time on the build sanding the rudder and fin assembly. Its nearly there but needs a bit more time adjusting the fits.
Thanks: Klipkopwildlife, Quorneng, boz, Squirrelnet
  • Ralpharr2001
07 Nov 2017 18:16 #35 by Ralpharr2001
Motor arrived today. According to Ecalc should be able to throw a 19 x 12 4 blade on 10S. If not then i'll fit a 22 x 12 two blade. The plan is to fit a Ramoser 4 blade unit that is statically adjustable so that I can tune the pitch to run on the efficiency curve of the motor assuming pitch speed is ok.
I can crack on with the front of the fuselage now and build the motor mount box.
Thanks: Eric, Klipkopwildlife, Quorneng, boz, Squirrelnet
  • Ralpharr2001
10 Sep 2018 18:18 - 10 Sep 2018 18:21 #36 by Ralpharr2001
Its been a while since I touched this build. Having a few days off between jobs I thought I would have another look at it. I have got bogged down with how the tailplane, rudder assembly went together. I looked at the photos of the fullsize and the plans and came up with my interpretation of how it should be.
Basically as designed by Vance Mosher the tailfin, tailplane and rudder is a single assembly that can be removed to access the rudder and elevator servos. The challenge was how? So I tackled the fin and rudder assembly first and sanded it down until it went together and operated quite smoothly. The fin tailpost sits down into the tail so I have glued a 3mm clinch nut to the fuselage then screwed the tailpost to it.
With the 3mm bolt in the tail post hat should hold the whole assembly into place and still be removable. The rudder has removable hinge pine so the rudder comes off to access the 3mm bolt.
The tail fin and rudder is glued to the tailplane which has two dowels at the front to locate it into the fuselage. Now the whole assembly:
Having nearly got this sorted i've got a bit more confidence to press on with the build. A lot of sanding and filling to do on the tail feathers but very close.
Last edit: 10 Sep 2018 18:21 by Ralpharr2001.
Thanks: Phil Wood, Eric, Klipkopwildlife, Flytilbroke, Quorneng, THE BLACKBIRD
11 Sep 2018 09:22 #37 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic Fairey Firefly MK5 from Vance Mosher plan
Another of your great builds Ralph, you pick some interesting projects, hows the Ganet coming along
  • Ralpharr2001
11 Sep 2018 13:45 #38 by Ralpharr2001
Thanks BB. Ah! the Gannet, yes its ehhhh........ coming along........sort of. I must actually pick it up again otherwise the woodworm will move in.
  • Ralpharr2001
11 Sep 2018 17:50 #39 by Ralpharr2001
Looking at the hinges on the model and comparing it to the full size i'm not impressed by the model design. The hinges are not in the correct positions when compared to the fullsize. So today I've undone some of what i did yesterday to get the hinges in the correct position. A lot of cutting and refabrication. Annoyed with myself for not spotting it earlier but was distracted by how the model assembly went together.
You can see the difference in the photo's:-
I'll post some photo's after the glue has dried.
Thanks: Phil Wood, Klipkopwildlife
11 Sep 2018 20:07 - 11 Sep 2018 20:08 #40 by THE BLACKBIRD
I had spotted the gaps, it will look better without them
Last edit: 11 Sep 2018 20:08 by THE BLACKBIRD.
  • Ralpharr2001
12 Sep 2018 12:19 #41 by Ralpharr2001
Modified rudder with two hinges in the correct position. Looks much better, Just needs tidying up with some filling and sanding to finish it off.
  • Ralpharr2001
22 Sep 2018 16:38 #42 by Ralpharr2001
Did a bit more on the Firefly. Had a bit of fun, cut and built the pilot and observer seats.
The plan for tomorrow is to cut all the parts for the flaps which involves more metal work. Can't wait! :whistle:
22 Sep 2018 18:02 - 22 Sep 2018 19:28 #43 by one tenor
Replied by one tenor on topic Fairey Firefly MK5 from Vance Mosher plan
Nice Job R. Metalwork ?[badass] You know you love it. It's a piece of P=+s as they say in the Pool. LOL[badass] You can do most anything with a Dremel. I just got a new one from Aldi £14:99 by E mail or £10 in store. Mains powered. Very fast at top rev 35,000s down to 8000 RPM. Screams like a banshee or high Kv brushless motor.Lots of accessories too. If you haven't already got something similar I advise you to get one. Bang Good do a good range. I've one of theirs too bout £8 IIRC. Good grinding.:woohoo:
Last edit: 22 Sep 2018 19:28 by one tenor. Reason: Correction and addition
  • Ralpharr2001
22 Sep 2018 23:19 #44 by Ralpharr2001
I have a Dremel but is getting a bit worn out. I may nip into Aldi and see if they have any left. Thanks for the heads up.
23 Sep 2018 09:28 #45 by one tenor
Mon plaisir monsieur
Time to create page: 2.414 seconds
