Basically all white with a purple tail end with minor "aluminium" detail and I just happen to have all these in Depron safe acrylic.
It is loosely based on the Thai Airways scheme who do operate the A350 - 900.
In fact I rather wish I had not made the wing tips when I did!
The one piece wing with its very delicate curly tips is a nightmare to handle particularly when going through the process of adjusting the fittings to mount the wing to the fuselage, in fact I very nearly cut them off!
It should still be just about 595 g (21 oz).complete with the wings painted as well
My initial target was 680 g (24 oz) so I am reasonably happy. The final 'acid' test will be the thrust is available using the 4s LiPo. Below a total of 400g and it will be pretty marginal.
Congratulations.
- Mike Rolls
- Thank you received: 573
Cough almost continuously if I lie flat so sleeping is a bit of problem.
- Thank you received: 10842
The dam weather over here in Bebington not far from you, no wonder your ill
- Flytilbroke
- Thank you received: 1987
- Mike Rolls
- Mowerman
- Thank you received: 139
Not a cure but may make you feel better
