DH 91 Albatross
31 Aug 2018 11:27 #106 by Quorneng
Replied by Quorneng on topic DH 91 Albatross
That did did not go well!
First the video did not work so I only have pictures of the result. :(
For the first 15 seconds it flew quite well and I concentrated of trimming, leaving the U/C down until it was flying nicely. Before it was flying smoothly all hell broke loose and it effectively "spun in" with the inevitable results. :woohoo:
Fairly serious this time.
The wing spar is broken in two places.
The U/C is completely deranged!
You may notice a prop and its nut is missing. I think this was the cause of the crash as it came off in flight (so lost) and with limited fin area the Albatross does not like asymmetric thrust!
Why did it come off with a conventional nut on a normal prop?
For some reason the ESC's have their 'brake' on. I don't know why but during the flight there appeared to be a momentary loss of signal causing the props to stop almost instantly. If not really tight the inertia of the prop can cause it to simply "spin off". Of course it had to happen on an outboard motor!
Had I realised what had happened I could have probably saved things better by cutting the throttle but when in a determined spin and certainly not 3 mistakes high the temptation is try to gain airspeed by adding power which in this case just made the situation worse.
Oh well never mind!
Gives me something to do. :P
Thanks: Phil Wood, Klipkopwildlife, THE BLACKBIRD
31 Aug 2018 14:14 - 31 Aug 2018 14:15 #107 by Eric
Replied by Eric on topic DH 91 Albatross
Is this where you start running round shouting - "Infamy, Infamy, someone's got it infamy!"
Sorry to see that, as it looks to be a pretty model. Still, that skinny little tail-end fuz didn't snap off as well! [badass]
Last edit: 31 Aug 2018 14:15 by Eric. Reason: typo
31 Aug 2018 15:26 #108 by Mowerman
Replied by Mowerman on topic DH 91 Albatross
I feel sickened for you Simon
31 Aug 2018 15:58 #109 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic DH 91 Albatross
Your not having much luck with this one Simon, sometimes thats the way it go's
31 Aug 2018 22:15 #110 by Quorneng
A start on the repairs.
The fuselage needed a bit of TLC as the fuselage/wing mounting had taken quite a jolt and the fuselage nose hold on was completely broken requiring a replacement of a fuselage former.
I suspect I will have to get 'creative' with the wing spar repair. I might try some carbon tow simply laid over the top of the breaks. :unsure:
The U/C is not actually such a problem but simply the amount of wing skin that will have to be cut away to remount the retracts units. ;)
The other 'rebuild' I am considering has nothing to do with the crash but the tail plane needs significantly more dihederal both for scale appearance and to aid fin ground clearance. Still thinking about it.
01 Sep 2018 17:44 #111 by one tenor
Replied by one tenor on topic DH 91 Albatross
Had to do same to full size TP
01 Sep 2018 21:39 #112 by Quorneng
Slowly restoring the undercarriage.
It has a new printed 'part' rib to hold each retract unit. While I was at it I printed 2 spares just in case. ;)
The spar has been repaired with carbon tow.
First the spar flange was sanded down to bare wood and then the tow 'flooded' in place with PVA glue.
It will take a day or two to dry out to full strength but should be almost invisible when filled and painted.
With the structural repairs complete it is now just a case of restoring the skin.
Thanks: Phil Wood, Klipkopwildlife, Flytilbroke, Mowerman, THE BLACKBIRD, Ralpharr2001
02 Sep 2018 10:32 #113 by Mowerman
Great progress, just shows - you can't keep a good man down. I suspect many of us would have given up.
03 Sep 2018 01:14 #114 by one tenor
Don't forget that tailplane. I think it'll pay off
03 Sep 2018 21:54 #115 by Quorneng
Getting there. The wing upper surface repaired and painted.
The other task today, apart from installing my daughters big new cooker, was to repair her 3 year old daughters' remote control dog.
Its eyes glow, it walks and 'yaps' in a very realistic and exceptionally annoying manner! :woohoo:
Much more serious is my 3D printer has failed - after just over 800 hours printing.
It looks like its the mother board (power is still ok) and judging by the number available on Ebay it almost certainly is! ;)
04 Sep 2018 06:19 #116 by Phil Wood
Replied by Phil Wood on topic DH 91 Albatross
I can't think of anything constructive to say, you've got everything covered. I will say, it's great to see someone with your tenacity & determination when it comes to model building. ..... Well done that man! :lol:
04 Sep 2018 23:13 #117 by Quorneng
Just for completeness the wing underside repairs finished & painted.
The repairs are visible but you have to look carefully. :)
Now I have to wait for the new prop - two complete sets this time! ;) and for the new mother board for my Anet A8 to make another spinner (lost with the prop) and to make the 3? new fuselage formers that will create the increased dihedral on the tail plane.
05 Sep 2018 17:39 #118 by Klipkopwildlife
Replied by Klipkopwildlife on topic DH 91 Albatross
Well at least you know what the problem was, is there any chance of unsetting the brakes?
06 Sep 2018 01:11 #119 by Quorneng
Klippy
Reprogramming the ESC could be a problem.
1. No programming info came with the ESCs
2. All the ESCs are coupled together and built in. I really don't fancy trying to count beeps on 4 ESC all at the same time.
The danger is I could end up with different characteristics on each ESC. :woohoo:
For now it will just have to be "do it up a bit tighter". After all 3 stayed on no problem. ;)
06 Sep 2018 12:54 #120 by Mowerman
Can't you get programming cards for those ESCs. So much simpler if you can. Sometimes cards from other makes will work.
Time to create page: 1.081 seconds
