DH 91 Albatross
As the dihedral angle is small I may be able to 'fudge' a universal joint between the elevators so a single fuselage mounted servo can be used.
The neatest way to operate twin rudders is with pull/pull cables, in my case with 5 lb nylon mono filament line.
Of course the lightest solution of all is to fix the rudders and fly bank and yank! :woohoo:
I think it will prudent to build a 'test' rudder and elevator installation so I have printed the formers for the rear section of the fuselage..
Which correspond to this, formers 12 to 17.
If it all works the 'test' assembly will simply be used in the final fuselage as it will have to be built in atleast 3 sections anyway.
The U/C legs (1/8 stainless!) bent to shape and fixed into the retracts.
Wheel down.
Wheel up.
As the U/C legs have no 'give' what so ever it uses printed sprung wheels.
The outer panels are only glued to the centre part at the rim which allows the axle 3 mm of vertical movement.
The "tyre" part is made up of three 6 mm Depron rings sanded to shape using a pillar drill.
The complete 60 mm (2 3 /8 ") diam wheel weighs 5.1 g.
- Mike Rolls
- Thank you received: 573
Anyway, as the wheel will have the rotating mass of practically nothing, would it matter?
- Mike Rolls
I am delaying fixing the retract leads permanently until I have built the centre section of the fuselage so I know exactly where I need them to come through the wing top skin.
Next I will make a start on the tail plane and rear fuselage.
Just as soon as the ESCs arrive from China I want to mount the motors to complete the electrical installation in the wing.
All Depron - 2 mm skins over two Depron shear webs with 3 printed elevator hinges.
I am slowly coming round to the idea of simply fitting a servo for each elevator as the tail plane is just about thick enough to hide them.
It would of course be equally simple to mount a rudder servo in each fin but I am very conscious of the weight of four of even the tiny 3.7 g types so far back. :ohmy:
Somewhere I do have a pair of even smaller 2.5 g servos or as electric motors usually don't 'stop' in flight I could go even simpler and fly bank and yank with fixed rudders.
However with 4 motors spaced out along the wing I suspect some 'rudder' might be useful to counter any thrust imbalance between them. )
Such an offset could be useful to counter motor torque except it will use two pairs of CW and CCW props!
The tail plane has dihedral so joining the elevator halves together so they could be driven by a single servo would require some sort of universal joint. Not easy to be both super light and slop free at such a small size.
The rudders could only be realistically linked by an external rod which would have to be half way up the fin to clear the 'up' elevator travel. It would thus not only be rather visible (and create drag!) but also very prone to accidental damage.
I suspect the 4 servo solution will give the neatest appearance and also be the easiest to install.
I may have to install all four motors in the wing to get an idea of how much they will counter the weight of the servos in the tail so the battery does not have to go too far forward in the nose.
I am not entirely happy with the fin to tail plane joint. It really needs a small printed internal brace.
As each hinge is printed in two parts, 5 hinges = 10 parts plus 2 horns and servo arm covers so 14 printed parts in each half tail plane and fin.
When complete the Albatross will have over 100! :ohmy:
To feed the rudder servo wire down the tail plane the pins have to be extracted from the plug. Having achieved this I glued the fin in place with its internal printed brace and left it to set. Big mistake! Sods law came into play. :woohoo: I should have tested the servo first.
Had to get fairly brutal with the knife to separate the fin from the tail plane and then a bit more to extract the servo from the fin.
Fortunately POR remains pretty pliable even after 24 hours so the 'repair' does not look too bad with the replacement servo in the fin, and tested
When it will be tested again!
