ASW 17 Sailplane
13 Jan 2026 13:45 #166 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic ASW 17 Sailplane
Things that pop up out of the wing
13 Jan 2026 15:29 #167 by THE BLACKBIRD
Got it together
13 Jan 2026 16:24 #168 by Quorneng
Replied by Quorneng on topic ASW 17 Sailplane
The air brakes are "top only" giving the ASW 17 a shallow maximum approach angle although there was apparently a factory fitted additional parachute brake option!
There was also a BGA approved modification to create more conventional top and bottom airbrakes that increased the available approach angle.
Not like the good old days where the T49 trainer glider's big air brakes kept it below its never exceed speed even in a vertical dive!
13 Jan 2026 17:15 #169 by THE BLACKBIRD
They do actually work then, i used to look at the ones on the vulcan bomber and think what use are those
  • Away
13 Jan 2026 17:47 #170 by Klipkopwildlife
Replied by Klipkopwildlife on topic ASW 17 Sailplane
The ASW 9 had no brakes but a deployable parachute making it almost impossible to land with any kind of dignity!
14 Jan 2026 01:55 - 14 Jan 2026 01:57 #171 by THE BLACKBIRD
I am not sleeping still and just looked on Leeds model shop at airbrakes  they start at £66 and go over 100 so if it gets ant ill make me own
But i dont think ill be bothering as im not be going to fly the thing
Last edit: 14 Jan 2026 01:57 by THE BLACKBIRD.
14 Jan 2026 08:27 #172 by jon.in.swansea
Replied by jon.in.swansea on topic ASW 17 Sailplane
The BMFA News latest mag on page 18 & 19 show some hill soaring models but none approach this aspect.
14 Jan 2026 11:59 #173 by THE BLACKBIRD
Hung it on my luggage scales, it said 1.334Kg
Thanks: Eric, Flytilbroke
  • Away
14 Jan 2026 12:38 #174 by Klipkopwildlife
Under 3lbs for a 4metre plane, can't be bad. I wish it would be here we could aero tow!
14 Jan 2026 14:09 #175 by THE BLACKBIRD
St needs wings tail plane covering fuse glassing
14 Jan 2026 21:22 #176 by THE BLACKBIRD
That aerotow comment got me thinking, will it or wont it, so i looked into it and unpacked the boxes
And yes it will but only just, it will not fit in the wooden box so it will not be coming back
Fuse and one wing in here
And the other sections in here
So i can just squeeze my stuff in as well, the rudder tailfeathers and elevator are inside the Bucker
Ill star to glass the fuse tomorrow then get a second coat of resin on over the weekend
So that its gone off by Tuesday and can go in the box
  • Away
15 Jan 2026 09:32 #177 by Klipkopwildlife
Wow! I will now inform you that you're never going back, I may have to nail one foot to the floor!
Thanks: Eric, THE BLACKBIRD
15 Jan 2026 11:37 #178 by THE BLACKBIRD
Not when you see the rubbish workmanship
15 Jan 2026 12:52 #179 by Eric
Replied by Eric on topic ASW 17 Sailplane
We've seen all the patches from when you couldn't find the servo leads!
15 Jan 2026 15:30 - 15 Jan 2026 15:35 #180 by THE BLACKBIRD
They were nothing Eric LOL its the ones where my fingers keep going through it
AND NOW a disastrous day in the shed i started the glassing of the fuselage
Laid the cloth on mixed up enough resin to do the job and more using her indoors scales as mine would not work, gave it a really good mixing and started spreading it on with an old  credit after a while i felt the paper cup with the resin in getting hot in my hand, it had started to go off, and quickly and melt my credit card
Not to amused as its expensive stuff the Wests resin, i thought i must have mixed it wrong, so mixed some more and carried on
Only to find the new cup getting hot in my hand again so rushed to got as much done as possible as i do not have any other
By this time it was foaming it the cup ( the first mix just went hard ) and choking me
Iv had it a while but not to long i got it to do the control line model
Then i had to sneak her scales back inside as she had come home
Im sitting here doing this post and my face is stinging from the fumes
Afraid it will have to go to S.A. like it is as i dont have time to get more resin sand it all back and do the top half
Last edit: 15 Jan 2026 15:35 by THE BLACKBIRD.
Time to create page: 1.312 seconds
