Obbys' Hurricane
  • obollox
  • Premium Member
  • Premium Member
04 Mar 2012 16:13 #46 by obollox
Replied by obollox on topic Obbys' Hurricane
Added some strips of carbon on the braces
04 Mar 2012 16:16 #47 by Ex-Member
Replied by Ex-Member on topic Re: Obbys' Hurricane
thats a good idea sir.
soon be flying then. :)
05 Mar 2012 23:12 #48 by Klipkopwildlife
Replied by Klipkopwildlife on topic Re: Obbys' Hurricane
What's the blue things Obby?
06 Mar 2012 00:17 #49 by Eric
Replied by Eric on topic Re: Obbys' Hurricane
Soft weights!
  • obollox
  • Premium Member
  • Premium Member
06 Mar 2012 07:26 #50 by obollox
Replied by obollox on topic Re: Obbys' Hurricane
They are ankle weights, used when scuba diving in a dry-suit. Very useful "soft weights" 500g each.
Started sheeting the wing last night.
06 Mar 2012 08:33 #51 by Grumpy42
Replied by Grumpy42 on topic Re: Obbys' Hurricane
Bugger! - now I'm going to have to go out and buy some Lego - luckily already have the SCUBA weights. More expense - mutter, mumble, mutter, grump, grump. Good idea though - why didn't I think of that? :unsure: :P :P :P
06 Mar 2012 12:57 #52 by Klipkopwildlife
The Lego idea's a good un! Trouble is I've got to ask er indoors to make me some soft bags!
  • obollox
  • Premium Member
  • Premium Member
06 Mar 2012 19:44 #53 by obollox
Replied by obollox on topic Jackboots
You could try some sand in the plastic bags props come in. The Lego idea I saw on another forum.
Anyone seen "jackboots on whitehall"
  • obollox
  • Premium Member
  • Premium Member
06 Mar 2012 19:57 #54 by obollox
Here you go
07 Mar 2012 15:56 #55 by Ex-Member
so hows it all going young man.
nearly finished yet.
  • obollox
  • Premium Member
  • Premium Member
07 Mar 2012 16:24 #56 by obollox
Hi Tony
Still baffled to know how you can build 4 of these! Got the sheeting done on the centre and have ordered some poly-c and tissue. I would like to try the silk I have with the polyc on some test pieces and use it to cover the fuse. If it doesn't work I can use the tissue.
Do you glue the tissue on before applying the polyc?
Can I use polyc as a sanding sealer?
07 Mar 2012 16:35 #57 by Ex-Member
cos they not built very well. :P
i used a sanding sealer before the poly c.
lay the tissue on dry and then paint the polyc on top and work out from the center.
if you get a crease you can just lift the tissue up and pull straight, then just run the brush over it again.
  • obollox
  • Premium Member
  • Premium Member
07 Mar 2012 22:15 #58 by obollox
Sounds easy :unsure:
Going to try and source some sanding sealer locally.
08 Mar 2012 02:34 #59 by Ex-Member
it is actually. :cheer:
  • obollox
  • Premium Member
  • Premium Member
14 Mar 2012 20:48 #60 by obollox
After a lot of fiddling I've got the flaps done. I thought it would be nice to have them coupled in with some landing lights,but i couldn't get the turnigy rx switch to work! Now to get on with sheeting the bottom of the wing.
Time to create page: 1.559 seconds
