top flite sea fury
29 May 2013 16:40 #136 by alan cantwell
Replied by alan cantwell on topic top flite sea fury
got to say, i have NEVER seen national markings and dont shoot me down stripes put on before the camo colour is applied!!!! but, if it works, then why not
29 May 2013 18:29 #137 by Ex-Member
Replied by Ex-Member on topic top flite sea fury
saves on paint.
why paint, then cover over with a different colour.
mr tight wad here. :P
29 May 2013 18:33 #138 by alan cantwell
hadnt thought of that, there is a lot of wing covered up with stripes, and round things i suppose
29 May 2013 18:37 #139 by Ex-Member
its a bit like painting the whole aircraft in brown, then putting the green camo pattern on top.
why waste paint, paint is money. :P
29 May 2013 20:19 #140 by Quorneng
Replied by Quorneng on topic top flite sea fury
Paint is also heavy!
30 May 2013 18:03 #141 by Ex-Member
well after sorting out the apple tree that decided to fall down during the night, i managed to get a little bit done.
all needs a second coat next and then panel lines and final sealing.
30 May 2013 20:52 #142 by Eric
Replied by Eric on topic top flite sea fury
Apple wood smells lovely when you put it on the fire! ;)
30 May 2013 21:40 #143 by Ex-Member
well all the roundels are finished and the white invasion stripes are done.
just the black to do tomorrow and then another coat of sky and grey, then panel lines and seal.
31 May 2013 17:59 #144 by Ex-Member
paint is done.
panel lines are on the underside of the wing.
Reg number is on the underside of the wing.
my eyes are crossed. :blink:
canopy turned up and i have cut the front off, made up a new former and started gluing them together.
cant decide whether to have the canopy open or closed.
31 May 2013 18:30 #145 by Eric
Might be quite draggy, and turbulate the fin, when open, Tony.
01 Jun 2013 11:55 - 01 Jun 2013 11:56 #146 by Ex-Member
Any whoo
i have done the first coat of sealant on the underside of the wing, done the few panel lines i want on the top of the wing.
made up the gun blisters and given the top 1 coat of sealant.
2 more coats on each side to go.
then fit the flaps and ailerons and chuck in the corner until i can.
A) fly better
B ) afford to fit it out.
be back to the Lancaster next week.
Last edit: 01 Jun 2013 11:56 by Ex-Member.
04 Jun 2013 17:59 #147 by Ex-Member
wing fits. :cheer:
sorting out the canopy next.
04 Jun 2013 20:58 #148 by Ex-Member
canopy screwed on.
06 Jun 2013 15:00 #149 by Ex-Member
hello
if you are interested i have done a bit more today.
made up the inner wheel well doors and fixed them on.
slopped a bit more paint about.
flaps are ready for covering then fitting.
that just leaves the ailerons and we are finished, apart from fitting out.
07 Jun 2013 13:22 #150 by Ex-Member
made up the reflector sight for the cockpit, need to paint it next.
started glazing the front of the canopy.
started covering the flaps.
Time to create page: 0.563 seconds
